First post, by AaronS
I've been trying for about an hour to remove this heatsink, the pen method doesn't work at all, they don't seem like those regular white "umbrella style" push pins from the back.
The attachment SAM_1963.JPG is no longer available
The attachment SAM_1965.JPG is no longer available
Reply 1 of 18, by Vynix
IIRC you need to pull the middle pin out, once that's done, you pinch the retaining "claws" on the bottom of the PCB and the heatsink should pop out.
Reply 2 of 18, by AaronS
These two? Do I need to be pulling these while pinching underneath?
Reply 3 of 18, by tehsiggi
Just pull them out, they spread out the two claws on the other side. No need to squeeze anything together while pulling them. If the won't budge, try to rotate them by 90 degrees and try again.
AGP Card Real Power Consumption
AGP Power monitor - diagnostic hardware tool
Graphics card repair collection
Reply 4 of 18, by AaronS
Okay I got the pins out, thanks. Next problem I assume the 20 year old glue is holding it onto the chip pretty damn well. Have tried heating it up but not budging. Any ideas?
Reply 5 of 18, by Repo Man11
AaronS wrote on 2025-11-11, 21:16:
The freezer trick has worked well for me. A few hours in the freezer has always worked to get stubborn fossilized thermal compound to break loose with some gentle pressure.
Reply 6 of 18, by DaveDDS
If it's that dried - prob. not doing good heat transfer either.
Make sure you can see nothing connecting from top to bottom - not familiar with this particular heatsink, but I have run into some over the years with extra/hidden attachment points.
Once you are sure there is nothing, try rotating the sink back and forth slightly and see if it will loosen - you might have to resort to prying it off.
Very easy to break things if you are not careful - I have a very small pry-tool I use in cases like this, and what I sometimes have to do it get it in place and then use an elastic or something to keep pressure on it - and let it sit that way for hours/days .. sometimes continued pressure will eventually get the pieces to "drift" apart.
And always worth trying heat/cold - sometimes a few cycles - thermal stress can also cause things to loosen.
Dave ::: https://dunfield.themindfactory.com ::: "Daves Old Computers"->Personal
Reply 7 of 18, by AaronS
Yeah there's only the heatsink and chip now.
I'll try the freezer thing, I assume this won't damage capacitors or any other components?
And yes it doesn't seem to get very hot, I detached the fan and ran 3Dmark01 and the rear of the chip gets hot to the touch (3ish seconds) but the heatsink only warm, (no thermal sensor to know exactly).
Reply 8 of 18, by AaronS
Okay couple hours in the freezer, followed by 20-30 seconds with hairdryer, stuck a credit card in there while twisting.
The attachment SAM_1971.jpg is no longer available
Horrible stuff you gotta pick off now. Thanks everyone. I wouldn't mind finding some aftermarket cooler but I don't think there's anything too good that doesn't take up multiple slots. I saw startech made a copper one but all long gone by now:
https://www.startech.com/en-gb/computer-parts … UUWCpHrrdc1MrQP
I'll just stick with this one.
Reply 9 of 18, by Pino
Acetone is great to remove this old yellow thermal material
Reply 10 of 18, by momaka
Pino wrote on 2025-11-14, 16:22:
Great? -Not really. But it is about as good as it will get (though still hard to remove.)
They way I do these, I use my heatgun and heat parts with the leftover thermal compound until too hot to touch but not so hot that it evaporates water (i.e. less than 100C). Then I take a sharp too and manually scrub as much of the material off as possible. And then finally I use small strips of paper towel soaked in acetone and scrub any leftover residue.
AaronS wrote on 2025-11-12, 00:01:
Looks like you have a card with 55 mm screw mounting, so there should be a number of stuff that fits and is better than the stock heatsink you have. But if you have the empty slots, why not go with one of those universal cheap generic 2-slot coolers? It would be both more quiet and run much cooler.
They still popup on Ebay every once in a while, though I find them a little too overpriced for what they are. More importantly, these are still very very loud coolers if you connect the fan as intended - directly to a 3-pin fan header. Basically, those small fans just scream away at full 12V. So not really a worthy upgrade if you're going to run them without some modding. I personally mod all of mine to run at 7V, which makes the fan pretty quiet, yet still pushes enough air to cool stuff. Of course, that copper cooler can handle a little more TDP than the cheapo stamped aluminum cooler shown on the card in this thread.
Reply 11 of 18, by AaronS
I only have 2 PCI slots and its at the bottom (it has a few extra mm in front of the fan, other slot is housing an Audigy soundcard).
Most of the single slot replacement heatsinks I can find on ebay look like they would be worse, and that was the only pure copper heatsink I came across. Not sure there's too many great options unfortunately.
Reply 12 of 18, by DaveDDS
You can get heat sinks where the fan is on a separate part connected with pipes (liquid cooling)
All of these that I've seen are very big, designed to dissipate a LOT of heat - but maybe there are smaller ones available for cases with less heat and space is tight - anyone know?
Reply 13 of 18, by tehsiggi
If you don't want to boil the ocean:
Single slot:
https://aliexpress.com/item/1005006293863620.html
Dual slot:
https://aliexpress.com/item/1005008872443559.html
Used both on cards already.. totally worth their money.
Even the single slot one should be equal or better from the performance, looking at the stock cooler and its "fins".
Reply 14 of 18, by kagura1050
It may be a little too thick, but this might be a good choice as it allows you to mount a reliable fan.
https://ja.aliexpress.com/item/32757356075.html
古いマシンで新しいOS(Linux/NetBSD)を動かすのが好き。
Timezone : UTC+9
Reply 15 of 18, by AaronS
tehsiggi wrote on 2025-11-16, 06:46:
Okay I did come across these but assumed they wouldn't be too great, but if you say they're good then I might order one. Funny thing is, I do kind of have one of these already, I bought a untested FX5600 ASUS card and, it basically has this exact heatsink (not sure if its copper or not), but I'd have to change the fan because its 3pin.
The attachment SAM_1980.JPG is no longer available
The attachment SAM_1982.JPG is no longer available
Might still be better just grabbing one of those since they're so cheap.
Reply 16 of 18, by tehsiggi
The same style of cooler has been used by Sapphire to cool cards like the Radeon X700 without issues, so I'd say it's well enough. I bought a five pack for cheap years ago and they are my goto "i need something to cool this during testing" method.
Reply 17 of 18, by momaka
If you don't want to boil the ocean: […]
Single slot:
Ha, nice, I didn't know these still existed for sale. 😀
These were popular on Ebay way way back... like 20 years ago, when most mid-range cards still used coolers like that.
And yeah, agreed that this one will have better cooling performance than the stock cooler. The stock cooler is barely more than an aluminum plate with a fan on it. For cards with under 10-15 Watts TDP (and especially older chips made with wire-bond technology), I suppose these are still OK.
But if you want a more quiet card, the solution is always to get a larger cooler (more surface area) and reduce the fan speed to only what is needed vs. going full blast (12V) all the time.
I'm very tolerant of noisy PCs, but even -I- get annoyed by the noise that those small fans make.
AaronS wrote on 2025-11-16, 21:18:
Yeah, these are not copper, just anodized aluminum to look like copper. I have both the anodized and non-anodized versions on various old GPUs. They perform exactly the same.
The fans can vary a little, though - some use really fast-running and noisy fans while others use slower and more "tame" fans... but at the expense of less cooling, of course. In any case, all of these coolers have approximately 4x the surface area of the stock cooler pictured on the card in the 1st post.
Indeed.
There's very little reason to fiddle with rewiring fans (or swapping fan connectors on the PCB, which sometimes I find easier than rewiring a fan), when such cheap option exists. Only thing is, it might take some time to come to you on the slow boat from China.
