Reply 2380 of 2408, by Roland User
Thank you for answer , I assumed what there is a possibility amplifier MIDI not use volume level , but use velocity level , this sometimes identificaly ) but I understand what if in MIDI file velocity set to max and next we increase velocity , result not will recive )
also , can ampli values in compliance with proportions for example :
MIDI FIle channels :
1 24
2 24
3 12
4 12
5 36
6 36
and if we set volume output as 100% , plugin transmit values 1:1 , if we set volume output as 200% , then transmit so :
1 48
2 48
3 24
4 24
5 72
6 72
and if on any channel was recive value 127 , more not increase volume on other channels
for example if in file available :
1 24
2 24
3 12
4 12
5 36
6 36
10 96
then :
1 32
2 32
3 16
4 16
5 48
6 48
10 127
