First post, by ElBrunzy
- Oldbie
Hello,
On this page, http://chukaev.ru54.com/video_en.htm there is a bios with VBE 1.2 and VBE 2.0 support for many S3 cards but not the Trio64V+ (86C765), there is only VBE 1.2 versions available. I was wondering if there is a reason for that or there is VBE 2.0 rom to download elsewhere as I would like to upgrade the card if possible.
I would also like to put an VBE 2.0 BIOS on the Cirrus Logic cards with a model number CL-GD5446BV-HC-A (I think the BV might be ignored for the ROM). There is a bios with VBE 1.2 support and, again, I would like to know if it's possible to upgrade that to VBE 2.0. The CL-GD5446 BIOS on that page is 1.25 and the one I have is 1.37 so I expect it not to support VBE 2.0 : https://www.vgamuseum.info/index.php/cpu/item … logic-cl-gd5446
Bye, thank you !
