Reply 40 of 47, by Grzyb
- l33t
ntalaec wrote on 2025-12-09, 10:04:Impressive! I was looking for a commander with minimal space requirements to use in a boot floppy disk. Could SP.HLP be integrated in SP.COM? In FAT12 filesystem (used by floppy disks) cluster size it's 4KB so a lot of space is wasted.
In my opinion, for use in a very disk space constrained setup, it's better *not* to integrate help in the executable.
That's a simple program, easy to learn - and once you thoroughfully learned it, you can delete the help file...
Nie rzucim ziemi, skąd nasz root!
