First post, by shaq
I have tried all drivers I could get my hands on and all versions of OpenAL32.dll I could find on the web. The sound will start missing voices after about 5 minutes. Every sound can be affected like reloads, pickups etc. The console in game shows that everything is fine. AlCapsViewer is good as well. I have used EFX and it is okay but I would really like to find out what is wrong with it if possible. Other games are not affected. I find it strange because it used to work for me a few years ago. Is this a common problem? I plan to test in W10 later on, but W7 is my main retro system. Thanks for any help.
Reply 2 of 11, by shaq
Yes I am using the latest Daniel K drivers and I tried all prior versions. Do you have any other ideas about what it could be?
I think it is because I'm playing Lost Mission in the original Doom 3. I figured if EFX worked then EAX should work but now I'm not sure. I'll test some more.
Reply 3 of 11, by lowenz
Have you installed them correctly? Because the behaviour you're reporting is the one of the basic Windows driver.
Reply 4 of 11, by shaq
I believe so. It's pretty foolproof to install in W7. Just click the boxes and install. I uninstalled just the driver and reinstalled it as well. Everything else works so far. Been playing Mafia with Dsound for hours. It must be a bug with running Lost Mission in the original Doom 3 engine since it was made for BFG.
Reply 5 of 11, by lowenz
shaq wrote on 2025-12-28, 05:13:
You must enable the installation of not signed drivers via the reg key.....because they're NOT signed, being NOT from Creative.
Reply 8 of 11, by agent_x007
This then : LINK ?
Reply 9 of 11, by lowenz
agent_x007 wrote on 2025-12-29, 23:00:
This then : LINK ?
But it's *exe patcher* for OpenAL Soft, not Creative OpenAL (I think no one tested it with Creative OpenAL, of course you can try 😁 )
Reply 10 of 11, by shevalier
shaq wrote on 2025-12-26, 14:18:
A couple of years ago, I played the original DooM3 on Windows 11 with X-Fi Titanium HD (PCI-e).
What kind of Fatality do you have?
PCI or PCI-e?
From what I know, the toughest test for Creative cards is the Unreal tournament 2004 with the mandatory ‘X-Fi patch’ installed.
https://www.techpowerup.com/14264/creative-re … atch-for-ut2004
An hour or two will show how well your sound card can handle the load.
Aopen MX3S, PIII-S Tualatin 1133, Radeon 9800Pro@XT BIOS, Audigy 4 SB0610
JetWay K8T8AS, Athlon DH-E6 3000+, Radeon HD2600Pro AGP, Audigy 2 Value SB0400
Gigabyte Ga-k8n51gmf, Turion64 ML-30@2.2GHz , Radeon X800GTO PL16, Diamond monster sound MX300
Reply 11 of 11, by lowenz
If you have a Creative card I remember that the OpenAL router (OpenAL32.dll by default) just points to the SPECIFIC Creative driver, CT_OAL.dll.
The best solution today is to:
1) unplug the Creative card
2) use OpenAL Soft, without any DLL router, just renaming soft_oal.dll to openal32.dll. It works in the 99% of the cases (you can still use the Router installer from Creative, to get openal32.dll and wrap_oal.dll, a simple OpenAL implementation for a DirectSound device but OpenAL Soft is totally superior unless you play the original STALKER Shadow of Chernobyl where sometimes you lose the audio /music and must press ESC 2 times - game->menu->game - to solve.....or swotch to a modern X-Ray engine version of SoC like OGSR or OpenXRay or IXRay, etc. )
-> https://openal-soft.org/
Doom 3 (the original 2004 one) and Quake 4 need the patcher named before, just to patch a bug. THEN you can use OpenAL Soft "CPU" driver.
But today I prefer RBDoom3BFG to play Doom3, and it use MicroSoft XAudio, so no need of OpenAL 😀
You can use OpenAL Soft as an alternative to ALchemy too, to get back EAX in DirectSound games, through DSOAL -> https://github.com/kcat/dsoal/releases (this package has already included a rolling release of OpenAL Soft)
