Reply 40 of 75, by MrFlibble
- Oldbie
Doomn00b wrote on 2025-12-27, 15:25:I've scratched that from the list - thanks! Those questionable ones never get much info.
On a second thought, though, I'm not really sure. Let's take KKnD and KKnD Xtreme for example. The latter is not only Windows-native, but also adds expansion pack missions which were never (IIRC) available for DOS.
You could kind of view Bubble Puzzle the same way: the base game (for DOS) only has random-generated puzzles, while Bubble Puzzle 97 also adds 50 (IIRC) hand-made levels in addition to the random level mode. Otherwise, the gameplay is the same between both versions.
Doomn00b wrote on 2025-12-27, 15:25:I got it from Mobygames - sadly they have NO SOURCES(!), so I may have been a bit rash there. 😳 They also don't have any product-codes for any of the releases, so we can't use those to see if we can find them in any kind of product-database of sold items either.
Uhh, I thought they fixed that obviously erroneous information. I guess whoever added that might have been confused by the existence of the original (non-PC) Conquest of Elysium in 1996-1997, and incorrectly conjectured it to be a PC release as well.
The problem here is solved very easily, as there are two DOS demo/shareware versions of the game from 1999, version 2.0 and version 2.2. Later releases of the demo include a version history (also available on the dev website), which clearly states that version 2.0 was the first PC release -- the game having been ported from Atari Falcon. Although I've not been able to track down the 2000 demo, it seems plausible that in 2000 the developers ported the game to Windows. You can get the later 2001 demo from GamesDomain FTP mirror (coedemo.zip), which is already Windows-native, and the changelog says "Much improved windows support" -- likely suggesting that the 2000 version was also for Windows.
The fact that version 2.0 (coe20pcd.zip), which is known to be a DOS application, is described by the authors to be the first PC version of the game invalidates any claim of a supposedly earlier Windows version.
Also it's probably worth noting that the PC version is called Conquest of Elysium II precisely because of the version number 2.0 of the first PC release, as it is identical to the original Atari Falcon Conquest of Elysium in all essential aspects. But, of course, the PC version then received various updates such as having more playable characters, and bug fixes, so it is not entirely the same thing as the original Falcon version.
On a vaguely related note, here's an interesting case for you when the DOS version indeed came later than the Windows version (well, sort of). There's an arcade-style vertical-scrolling shmup called XOP, which was programmed using Allegro and was originally sold as shareware in the early 2000s. Author Christopher Emirzian later declared the game freeware. AFAIK, this version was Window-only. In 2011, Christopher released an updated freeware version of the game called XOP Ultra, for which a DOS version is also available alongside the Windows version.
You can read some history of the project as related by Christopher here.
Unfortunately, the post-2002 release of XOP Ultra means it falls outside of your current scope.
Doomn00b wrote on 2025-06-27, 14:01:Modern recreations, remasters and 3rd Party remakes are not included. I place the cut-off point at 2002.
I'd still suggest to add Abuse for Windows (2001) by Jeremy (Marauder) Scott. While it was not created by the original developers of the game, Scott received permission from them to include the full version's data files (which were not covered by the original PD license release of the source code + shareware data) with his Windows port, as per the readme:
This is the retail version of Abuse's data files, with the Win32 executable. Many thanks go out to Jonathan Clark and Dave Taylo […]
Many thanks go out to Jonathan Clark and Dave Taylor for granting me
permission to redistribute the retail data set.
Thanks also to Justin Cassidy for helping with the testing, and to everyone
at the Abuse message board (www.abuse2.com) for invaluable feedback.
Possibly even stronger cases would be HacX 1.2 (runs on Win and other platforms using ZDoom) and Chex Quest 3 by Chuck Jacobi (one of the creators of the original Chex Quest), but, again, these came out in late 2000s/early 2010s.
Also I remembered that a while ago, I found a Wayback Machine copy (in good condition) of a 90s online multiplayer service that had free multiplayer clients of Panzer General and Castles II available for download. I think I was able to download either both or only PG, but of course, they'd only work with said service (I don't remember if it was MPlayer.net, TEN or something else altogether). I'm not sure if this is of any indication if a complete Windows-native version of Castles II existed or not. I only know there was a CD re-release, and a website hosted a big demo (likely taking up an entire CD's worth), but said demo had intricate copy protection which required it to only be run from an actual CD, so I didn't bother experimenting with it. It could be only DOS though.
