First post, by MrFlibble
Somehow I discovered this just now, but in 2025 Frenkel made a functional DOS VGA port of the Mac version of Wolfenstein 3D (based on the original Mac code):
https://github.com/FrenkelS/Wolf3D-Mac-for-DOS
The attachment macwolf.png is no longer available
The port is fully playable and comes with converted Mac shareware (The First Encounter) data files. However, it does not have any menus whatsoever, since the original Mac version made use of the MacOS window system GUI for all the menus. You can choose the difficulty level from the command line, but no save or load game yet. Mac mods are also supported, but you need to convert the data files yourself.
The port currently runs in 320x200 VGA Mode13h or Mode Y, the former giving noticeable screen tearing, and the latter will display sprite flickering in DOSBox if cycles are over around 20,000.
A good while ago I played the actual Mac shareware version using Executor, and had the impression that it uses 1:1 pixel ratio. The title screen is always rendered in 640x480, and while you can set the in-game resolution to 640x400, it is still rendered as letterboxed picture on a 640x480 screen. If you run the game in 640x480, it won't stretch the 640x400 image to 4:3 dimensions, but will instead draw the viewport area over the status bar to fill the 640x480 space, both in 1:1 pixel ratio.
DOS Games Archive | Free open source games | RGB Classic Games
Reply 1 of 6, by Frenkel
This port started as a quick project to see how the renderer works and if it could improve the renderer in Doom8088 (short answer: no). And then it grew when I added features that aren't in the Mac version, like palette changes when the player get hurts/picks up items, WASD + mouselook controls and PC speaker sound effects. Resizable view and automap is implemented differently.
A few months after the release of MacWolf for DOS, LateGator also released a port of MacWolf: MacWolfSDL runs on Windows, macOS and Linux.
Reply 3 of 6, by Bondi
Cool! Thanks for posting this here and for making the port, of course! Port of a port - love this kind of weird stuff 😀
Tried this in Dosbox and yes, it's flickering like crazy. If I turn down the cycles so that it doesn't flicker - it becomes very slow, almost unplayable.
Anyways looking forward to seeing further development of the port...of the port
PCMCIA Sound Cards chart
archive.org: PCMCIA software, manuals, drivers
68pins.com custom PCMCIA drivers
Reply 4 of 6, by MrFlibble
Frenkel wrote on 2026-01-11, 08:58:
Thanks for the info, I suspected someone would do it, but prolly didn't look hard enough.
Do you plan to work further on your port? It's very playable and has a lot of potential IMO.
In addition to my thoughts concerning how the menus could be reimplemented that I posted at GitHub, I remembered that Geoworks Ensemble is now freeware under the Apache 2.0 license, perhaps its GUI could be used to integrate the menus? (just throwing wild ideas around)
Reply 5 of 6, by zyzzle
I'm a bit unclear on how to get the other episodes (Second and Third encounters) into the game without recompiling the game. Does the binary release support these other episodes out of the box? Please clarify and explain. It is stated that "you need to supply your own data files." I have the data files, but apparently not in the right format and / or the current binary (7-16-25 release) doesn't support them.
Reply 6 of 6, by Frenkel
MrFlibble wrote on 2026-01-11, 21:09:
Fixing the Pac-Man Ghosts and adding multi channel audio both have a higher priority than adding menus.
zyzzle wrote on 2026-01-12, 21:29:
The short answer is: That binary does support the other episodes. To create the WAD files, download the Wolfenstein 3D data files from archive.org, install Java and Maven and run mvn verify.
