First post, by stealthjoe
I was using Glidos 1.29 for quite a while on my Win 98SE. Had to reinstall my OS and tried to install the latest vesion. The Glidos version 1.59 throws an error that it requires a higher windows version. The version 1.55 installs and opens fine but as soon as I try to run Tomb Raider, the dosbox window stalls. Same case for UB as well. Haven't tried other games yet. Any fix for the 1.59 version on 98 SE?
Intel 845GEBV2, Pentium 4 2.4 Ghz, Geforce FX5600 256MB, 512MB RAM, 160GB HDD, Sound Blaster Live! SB0100 - Win 98.
Reply 1 of 15, by Glidos
With 1.59, is it the installer that is giving the error? If os, you might try https://download.glidos.net/Glidos_v1_59_xp.exe (I realise it isn't XP you are targetting, but there's a chance it might work).
For 1.55, try changing the Glidos configuration, under the Dos tab, change Dos Emulation to Windows.
Reply 2 of 15, by stealthjoe
Glidos wrote on 2025-10-10, 13:00:
Yes indeed. While running the 1.59 installer, it prompts the error on 98SE. I did try changing the Dos Emulation to Windows for 1.55, but the game doesn't open afterwards. While using the default mode (DOSBOX emulation), it was working the first time. However, during the subsequent times, the DOSBOX window just stalls.
Reply 3 of 15, by Glidos
That's strange. Setting "Dos Emulation" to "Windows" is definitely the right choice for running under Windows 98. I'm struggling to think how it might work at all with DOSBox. The communication between the game and Glidos is entirely different under 95/98. Come to think of it, when trying to run under Windows 98, it's probably best to get TR I running in softwere mode first to make sure you have any config correct.
Did you try the XP installer for 1.59? It's not really specific to XP. It's my old bespoke Glidos installer, from before i swapped to the standard inno setup.
Where are you finding Glidos 1.55? I don't see it on download.glidos.net. Not sure why it isn't there. I tended to keep all old versions.
Reply 4 of 15, by vvbee
Also wasn't getting Glidos 1.59 to run in Windows 98, just froze on the DOS screen, although randomly but rarely the game would start up. Seems there may be a typo in /OVL/pipe.c for glide2x.ovl that prevents the OS from being detected correctly, using jp instead of jmp in two places. I'm rusty on my assembly but this was AI's catch, and changing these does appear to make it work.
Reply 5 of 15, by Glidos
Wow! Interesting. The explanation doesn't sound quite right. Back in the days when 98 was current, it worked reliably, and I'm pretty sure that file hasn't been altered since that era. But having it work after making the change is compelling evidence. If you can get a definitive fix, I'll work it into a new download version.
Reply 6 of 15, by vvbee
To me the explanation does make sense, since why would you be interested in the parity flag in this context? This is the code, you tell me:
#pragma aux detect_os =          \
"mov cx, es" \
"mov dx, di" \
"mov ebx, 0h" \
"mov eax, 1684h" \
"int 2fh" \
"mov bx, es" \
"or bx, di" \
"jz nt" \
"mov bx, es" \
"sub bx, cx" \
"sub dx, di" \
"or bx, dx" \
"jz dosbox" \
"mov eax, 0h" \
"jp exit" \
"nt: mov eax, 1h" \
"jp exit" \
"dosbox: mov eax, 2h" \
"exit: mov es, cx" \
parm [edi] \
modify [eax ebx ecx edx edi] \
value [eax];
So it's DOSBox if !bx|dx, otherwise Win 98, but actually nevermind if bx|dx from a few instructions ago had an even number of 0s we fall through NT with the same parity check and into DOSBox again. Doesn't sound right.
The code has no license as far as I can tell, so a definite fix would have to come from you.
Reply 7 of 15, by Glidos
Oh yeah. 😀 Sorry for doubting - I think you're right. It is the sort of mistake I can imagine making. Strange not to have picked it up at a later date, though. I'll see if I can find the tools I used to build this.
Possibly I should add a licence file too. I'm happy for people to do whatever they want with it. BSD maybe.
Reply 9 of 15, by vvbee
That works, thanks. Verified by testing with default files => doesn't work (freezes after DOS4/GW banner with Screamer 2), adding new OVL => works.
I also notice now that if I install sound drivers then the default Glidos works as well. If I disable the audio device from the BIOS then the default Glidos goes back to not working, but works again with the new OVL. It's not an audio issue since the OVL change doesn't touch on audio, and in any case I have the audio options off in Glidos, but since memory addresses were involved in the parity flag then presumably on my system at least having audio enabled has a lucky effect on the memory layout. Or maybe this is typical in Windows 98.
Reply 10 of 15, by marxveix
Win98SE and Glidos_v1_59_xp.exe works and Glidos_v1_59.exe does not.
Best ATi Rage3 drivers for 3DCIF / Direct3D / OpenGL / GLUT / DVD : ATi RagePro drivers and software
33+MiniGL / OpenGL Win 9x dll files for all ATi-Rage3 based cards : Re: ATi RagePro OpenGL files
Reply 11 of 15, by vvbee
Came across an instance where the original OVL didn't work under the condition that sound is enabled. Booted into Windows 98, ran Glidos, froze at DOS4/GW. Restarted Glidos a few times, same issue. Replaced the OVL with the fixed one, worked. Put the original OVL back, didn't work, then the fixed OVL, worked. After rebooting, the original OVL started working again as well.
I'm running this on a Pentium 4 system. Maybe later platforms if not later versions of Glidos are more likely to trigger the bug.
Reply 12 of 15, by Glidos
Maybe that's a good result. It's consistent with the new version fixing an intermittent problem.
Reply 13 of 15, by vvbee
Just some data for whoever comes across the issue later. Seems in theory you could make it likely to always fail or work just by adding or removing a driver in your config.sys or upgrading your motherboard or even BIOS for example, anything that might shift the relevant memory layout. Not that it matters now, but out of interest in the case that the odds weren't 50/50 across the various systems people have or had.
Reply 14 of 15, by Glidos
I'll upload new version of Glidos when I get some time. Thanks again vvbee.
Reply 15 of 15, by AaronS
Hello, just recently learnt of this app and wanted to give it a try under 98SE. As above the "_XP" installer was needed but for me Tomb Raider doesn't work, it plays the FMVs and then goes back to desktop with the DOS prompt however the game can still be heard in the background and I can even select new game etc. I have DOS Emulation set to Windows, checked and unchecked a bunch of options but still nothing. Also tried the updated Glide2x.ovl from above but no difference.
GPU is a Nvidia Quadro FX600 from 2004 running driver 56.64.
I saw people mentioning 1.29 with 98SE and that does work. Has anyone had success with 1.59_xp with 98SE and TR1?
EDIT: 1.32 also works, 1.33 is when it breaks (for me), I get missing DLL issues related to networking trying to run 1.33 ~ 1.58. My system has no NIC installed (disabled in the bios).
EDIT 2: Okay I got it working with 1.59_xp, the above fix, 98SE and the Quadro. I instead used Nvidia driver 45.23 (I don't think this matters) and originally was using the Voodoo Rush patch from philscomputerlab (I think other Glide methods recommend this one) and I saw you have a "TrAndUbForGlidos.exe" on your downloads directory. Using that and in Glidos 1.59 I have to use openGL and tick Fullscreen. FMVs, SFX, redbook audio and most importantly beautiful Glide graphics all working.
