Hello, just recently learnt of this app and wanted to give it a try under 98SE. As above the "_XP" installer was needed but for me Tomb Raider doesn't work, it plays the FMVs and then goes back to desktop with the DOS prompt however the game can still be heard in the background and I can even select new game etc. I have DOS Emulation set to Windows, checked and unchecked a bunch of options but still nothing. Also tried the updated Glide2x.ovl from above but no difference.
GPU is a Nvidia Quadro FX600 from 2004 running driver 56.64.
I saw people mentioning 1.29 with 98SE and that does work. Has anyone had success with 1.59_xp with 98SE and TR1?
EDIT: 1.32 also works, 1.33 is when it breaks (for me), I get missing DLL issues related to networking trying to run 1.33 ~ 1.58. My system has no NIC installed (disabled in the bios).
EDIT 2: Okay I got it working with 1.59_xp, the above fix, 98SE and the Quadro. I instead used Nvidia driver 45.23 (I don't think this matters) and originally was using the Voodoo Rush patch from philscomputerlab (I think other Glide methods recommend this one) and I saw you have a "TrAndUbForGlidos.exe" on your downloads directory. Using that and in Glidos 1.59 I have to use openGL and tick Fullscreen. FMVs, SFX, redbook audio and most importantly beautiful Glide graphics all working.
