First post, by DustyShinigami
- l33t
Okay, so, this hasn't really happened before until now, but since trying The Longest Journey (the original 4 CD release) I keep randomly getting DDHELP and Rundll32 Illegal Operation errors. I'm not sure if it's because I'm using a Geforce 4 Ti 4200, the drivers I'm using, which are currently 45.23, and I've had no problems with them so far, or if it's because I've overclocked my Pentium III from 466 to 933. Again, doing that has always been fine. I've yet to overclock the GPU so it's closer to default clock speeds for this model.
When I tried to load the game, I was hit with one of those errors (I forget which now) and the system locked up, forcing me to reset the PC. I tried again, thinking it was just random bad luck, skipped all the intros and got to the beginning area, and the game crashed with the DDHELP error. I read online that setting the desktop resolution to 640x480 before loading a game should solve it. Tried it and was instantly hit with the Rundll32 error. System locked up. Reset. Set the resolution, loaded up the game, skipped the intros, played around for a bit, all seemed fine. Quit the game, went to set my resolution back to 800x600 - got hit with the Rundll32 error again. Switched off the PC.
Wondering if anyone else has encountered these errors in a similar pattern to this? Or specifically with this card? And what helped for you? Thanks.
OS: Windows 98 SE
CPU: Slot 1 Pentium III Coppermine 933MHz (SL448)
RAM: Kingston 256MB 133MHz
GPU: Nvidia 16MB Riva TNT/128MB Geforce 4 Ti 4200
Motherboard: ABit AB-BE6-II Intel 440BX
Sound Card: Sound Blaster Live Value CT4670
