Battle of the platforms: socket 939!
Reply 60 of 76, by nd22
6. 1280*1024 AA 4X with sound:
A. KU8
B. KV8 PRO
C. UL8
D. AV8
Reply 61 of 76, by nd22
7. Code creatures 1600*1200 AA 4X:
A. KU8
B. KV8 PRO
C. UL8
D. AV8
Reply 62 of 76, by nd22
8. Code creatures 1600*1200 AA 4x sound:
A. KU8
B. KV8 PRO
C. UL8
D. AV8
Reply 63 of 76, by nd22
Code creature summary: even with an overpowered video card the maximum difference between the single channel socket 754 and the dual channel socket 939 is 5.9%, far below the 9.4% suggested by the PR of these processors.
Also despite being a Directx8 benchmark and using a radeon x1950 pro at 1600*1200 all 4 systems perform within 2% of each other! So a true directx8 card - such as geforce4 ti4600 - would give you horrendous performance; and it's 100% true - for high performance in Directx8 games you need a good Directx9 card; for high performance in DirectX7 games you need a good directX8 card and so on.
Reply 64 of 76, by nd22
9. We switch to Aquamark3, the first DirectX9 benchmark to ever be released and start at default settings: 1024*768, AF 4X, no AA, no Sound:
A. KU8
B. KV8 PRO
Reply 65 of 76, by nd22
C. UL8
D. AV8
Reply 66 of 76, by nd22
AV8 leads the pack even if by the tiniest of margins - the same happened with the code creatures results!
10. 1024*768 maxed out settings, including sound:
A. KU8
B. KV8 PRO
Reply 67 of 76, by nd22
C. UL8
D. AV8
Reply 68 of 76, by nd22
For the first time ULI manages to score a victory by leading VIA with a very small margin!
11. We go up to 1280*1024, without sound first:
A. KU8
B. KV8 PRO
Reply 69 of 76, by nd22
C. UL8
D. AV8
Reply 70 of 76, by nd22
12. ... and with sound:
A. KU8
B. KV8 PRO
Reply 71 of 76, by nd22
C. UL8
D. AV8
Reply 72 of 76, by nd22
13. We reached the grand daddy of retro resolutions: 1600*1200
A. KU8
B. KV8 PRO
Reply 73 of 76, by nd22
C. UL8
D. AV8
Reply 74 of 76, by nd22
14. Final and most demanding settings: 1600*1200 max details with sound:
A. KU8
B. KV8 PRO
Reply 75 of 76, by nd22
14. C. UL8
D. AV8
Reply 76 of 76, by nd22
In Aquamark ULI manages to hold its own, buckling only at the 1600*1200 resolution! It's practically a toss-up. Again the difference between the dual channel and single channel Athlon 64 is 5% at most. There is no result until now that would validate the PR rating of the Athlon 64 3500!
