First post, by gescolino
Hi all,
Thanks a lot for this software!
I've just a little question: i have an old software (reachout) that is a vnc like and run into windows 3.1 but i can't have my physical modem recognised.
Could you help me please?
Thanks in advance.
Reply 1 of 13, by h-a-l-9000
Rank DOSBox Author
DOSBox Author
did you change the serial1= in dosbox.conf?
1+1=10
Reply 2 of 13, by gescolino
Ok now i can see the modem but there is some other problems.
I think that my modem don't understand all the commands send by the software (unhandled command) and finally when i want to connect to the other host by is phone number, i have a : modem response: NO CARRIER.
The listening port is the port 23.
Is there another port to set?
Or another thing to do?
Thanks in advance for your help!
Reply 3 of 13, by h-a-l-9000
Rank DOSBox Author
DOSBox Author
Do you want to communicate by a real modem built into your computer? In that case you need to use directserial, not modem.
1+1=10
Reply 4 of 13, by gescolino
ok i have set directserial but i don't know what to put in realport?
Thanks a lot for your help!
Reply 6 of 13, by gescolino
ok perfect!
Now i can make the phone number but there is another problem.
(desired serial mode not suppported) and the software freez on:
"login on to host"......
Reply 7 of 13, by gescolino
I'm sorry but no one has an idea?
Reply 8 of 13, by wd
Rank DOSBox Author
DOSBox Author
Nope.
But feel free to post a screenshot of the error.
Reply 9 of 13, by h-a-l-9000
Rank DOSBox Author
DOSBox Author
can probably be ignored.
Does the DOSBox Status Window show some error messages?
Try a CVS build too.
1+1=10
Reply 10 of 13, by gescolino
that's the log:
I'm now trying to install a CVS one.
Reply 11 of 13, by h-a-l-9000
Rank DOSBox Author
DOSBox Author
As it tries to use the FIFO you could try the build from my homepage too. 5 and 6 are weird baud rates though...
1+1=10
Reply 12 of 13, by gescolino
everything is ok now.
i need to do a "ctrl+esc" in the dosbox but when i do that dosbox crashes...
is there a special key to press to do that?
thanks for your help!
Reply 13 of 13, by wd
Rank DOSBox Author
DOSBox Author
check the readme (mapper section)
