WP32 McCake : MT32 compatible waveblaster board
Reply 460 of 463, by NeoG_
Shiftyy wrote on 2026-05-05, 17:45:
EDIT: Ahh dang, it looks like the RPi that came from Serda's shop doesn't have the WiFi module. Other than installing Linux on my machine, does anyone have ideas for accessing the .img files?
The easiest way (in my opinion) would be to use VirtualBox and get a pre-made linux VHD from OSBoxes, passthrough your SD card reader to the guest machine and then mount the img file as an ext4 folder
98/DOS Rig: BabyAT AladdinV, K6-2+/550, V3 2000, 128MB PC100, 20GB HDD, 128GB SD2IDE, SB Live!, SB16-SCSI, PicoGUS, WP32 McCake, iNFRA CD, ZIP100
XP Rig: Lian Li PC-10 ATX, Gigabyte X38-DQ6, Core2Duo E6850, ATi HD5870, 2GB DDR2, 2TB HDD, X-Fi XtremeGamer
Reply 462 of 463, by NeoG_
appiah4 wrote on 2026-05-06, 06:22:
It seems WSL2 allows mounting EXT4 in Win11:
https://learn.microsoft.com/en-us/windows/wsl … wsl2-mount-disk
Alternatively you can use any of a gazillion Linux live distros out there to do the job.
Seems like it doesn't support USB drives, card readers or mounting from .img files
Reply 463 of 463, by Shiftyy
So I downloaded VirtualBox and tried mounting the .img files.
Apparently these img files are RPi kernel boot files and don't actually contain any files or filesystem.
I am confused because I can't locate the MUNT files or code. Has it been obfuscated into a .bin file or something?
