EDIT: Ahh dang, it looks like the RPi that came from Serda's shop doesn't have the WiFi module. Other than installing Linux on my machine, does anyone have ideas for accessing the .img files?
The easiest way (in my opinion) would be to use VirtualBox and get a pre-made linux VHD from OSBoxes, passthrough your SD card reader to the guest machine and then mount the img file as an ext4 folder
98/DOS Rig: BabyAT AladdinV, K6-2+/550, V3 2000, 128MB PC100, 20GB HDD, 128GB SD2IDE, SB Live!, SB16-SCSI, PicoGUS, WP32 McCake, iNFRA CD, ZIP100
XP Rig: Lian Li PC-10 ATX, Gigabyte X38-DQ6, Core2Duo E6850, ATi HD5870, 2GB DDR2, 2TB HDD, X-Fi XtremeGamer
So I downloaded VirtualBox and tried mounting the .img files.
Apparently these img files are RPi kernel boot files and don't actually contain any files or filesystem.
I am confused because I can't locate the MUNT files or code. Has it been obfuscated into a .bin file or something?
Could you just backup on the configs, SoundFonts, and ROMs and just rebuild the card with the latest release of MT32Pi? Even better if you have a spare card you can test with.
I just want to locate the MUNT files. Recompiling mt-32 does not achieve this.
It's not recompiling. It's just updating to the latest release which would include the WiFi module and whatever other changes and fixes happened since the version you have.
PS D:\Downloads\mt32-pi-0.13.1> D:\Downloads\mt32-pi-0.13.1\find.ps1
Press Enter to continue...:
edit2:
Memory says the kernel images are compressed (gzip?), so let's see about extracting them and see if it's in there?
jright-click, 7-Zip, Open archive... run the thing again GOTCHA!
D:\Downloads\mt32-pi-0 […] Show full quote
D:\Downloads\mt32-pi-0.13.1\kernel8-rpi4
Picking the correct kernel image for your Pi (look in config.txt!), editing it, re-compressing the kernel image and putting the stuff on the SD is left as an exercise for the reader (assuming I don't get bored while making dinner and want to see my front-panel say "butts butts butts") 😀
edit3: got bored, started doing it:
hexed.it is happily opening the decompressed files and finds the bytes, for the kernel8 for a Pi 3/Zero2, I think you're looking between 0x000F0310 and 0x000F0B80.
DJNWwrote on 2026-05-12, 14:45:A thought - could you break out a hex-editor on the raw .img and change the existing hash values to the hashes of your edited […] Show full quote
A thought - could you break out a hex-editor on the raw .img and change the existing hash values to the hashes of your edited files directly?
(Assuming compiling hasn’t turned them into something unrecognisable)
ed: Curiosity overtook me, some quick-n-dirty PowerShell to do a recursive search didn't bring anything, except the .ps1 that was doing the search 🙁
edit2:
Thank-you so much. Yes, extracting the .img file using 7-zip was the key, and I can now locate the SHA-1 hashes we need to replace.
I can confirm that it is working.
A bit of advice for anyone else wanting to do this;
The SHA-1 value that you replace needs to be in lower-case.
The replacement string cannot be longer than the old one, only shorter or the same size.
If your replacement string is shorter than the old string, replace the rest of the characters with "00" in your hex editor.
