First post, by DustyShinigami
Hi
So, I installed my original 4-CD version of Tex Murphy: Overseer the other day, and I'm trying to find out a bit more about the DVD version. I understand that was released in the States only...? I don't think it came out in the UK. The versions sold on Steam and GOG are the DVD versions, which I know have cleaner and higher res FMV videos. No scanlines. I presume they include some pre-installed patches/fixes as well? I would like to get those higher res videos working with my installed version, along with any patches/fixes, if that's possible? Or is there a way of converting the original CD versions to match the DVD version? I know there's a guide for converting the CD version to a DVD disc, but that doesn't guide you on how to install it so it plays from the HDD. Plus, my Win98 PC doesn't have a DVD drive. Yet.
Thanks
OS: Windows 98 SE
CPU: Slot 1 Pentium III Coppermine 933MHz (SL448)
RAM: Kingston 256MB 133MHz
GPU: Nvidia 16MB Riva TNT/128MB Geforce 4 Ti 4200
Motherboard: ABit AB-BE6-II Intel 440BX
Sound Card: Sound Blaster Live Value CT4670
Reply 2 of 37, by DustyShinigami
Garrett W wrote on 2024-11-20, 13:36:
Overseer came out simultaneously on CD and DVD, the original release included them both. You may want to check this thread out:
Tex Murpy Overseer DVD Edition Being a Pain
Huh. I had no idea they came out at the same time. Or that both versions were included. I could be wrong, but I think the only release to come out in the UK was the regular CD version part of the Premiere Collection.
OS: Windows 98 SE
Reply 3 of 37, by DustyShinigami
Okay, I have everything you suggested except for DVDExpress. That one seems a bit elusive now.
OS: Windows 98 SE
Reply 4 of 37, by DustyShinigami
Is Mediamatics DVDExpress definitely needed? Or is there an alternative? Any links I've come across for it appear to be dead.
OS: Windows 98 SE
Reply 5 of 37, by DustyShinigami
Any suggestions regarding this? I've still been unable to find DVDExpress; only an update. So unless there's an alternative that works...?
OS: Windows 98 SE
Reply 6 of 37, by DustyShinigami
Now that I’ve managed to get/find the tools needed, and reinstalled Overseer again with the update (1.04), does using those tools actually help with converting the FMVs to MPEG/DVD quality, or are they purely for converting the CD versions to a DVD to avoid disc swapping?
The latter I’m not too fussed about (yet). What I am unsure about is the process of getting the higher quality videos.
OS: Windows 98 SE
Reply 8 of 37, by DustyShinigami
RetroPCCupboard wrote on 2025-02-07, 09:01:
DustyShinigami wrote on 2024-11-20, 13:25:
Interesting. My version is 5 CDs. I am from UK too.
Oh, I think it is 5 CDs actually. My mistake.
OS: Windows 98 SE
Reply 9 of 37, by DustyShinigami
I've come back to this as I still haven't solved this problem. Going through some threads, I'm still not sure if I'm supposed to be converting my CD version to the DVD version...? And that the steps outlined in Tex Murpy Overseer DVD Edition Being a Pain will only work if using the DVD version...? I'm guessing that's the case. I installed everything suggested, but there's no change. And there's certainly no 'DVD Express option from within Overseer's settings menu'. Again, I'm guessing this refers to the Hardware/Software options...?
OS: Windows 98 SE
Reply 10 of 37, by xcomcmdr
I played a lot with the DVD version of Overseer decades ago.
IIRC, you just need to install the DVD version, and have a MPEG-2 (and AC-3 ? I can't remember) decoders enabled. Not the directshow one, but a VfW one.
Back in the days, it worked great with a version of ffdshow tryouts old enough to run on Windows 98SE:
https://ffdshow-tryout.sourceforge.net/
(I had a lot of troubles outside of Windows 98)
Failing that, you could try Windows XP or later, still with ffdshow tryouts DirectShow and VfW decoders for MPEG-2 video enabled. But the game really preferred Windows 98SE.
I've never seen that DVD Express menu. All versions of the game that I could get were already patched to work with any MPEG-2 software decoder through VfW (Video for Windows).
Reply 11 of 37, by BEEN_Nath_58
Some MPEG2 games I tried run with a combination of Elecard MPEG player and LAV Audio. If you are on WIn98, you will need some other audio decoder maybe
Reply 12 of 37, by DustyShinigami
xcomcmdr wrote on 2026-05-22, 06:16:
I played a lot with the DVD version of Overseer decades ago. […]
Okay, thanks for confirming. 😀 So I'll need to look up how to convert my CD version to DVD and install that. So far I've installed Mediamatics DVD Express (4, I believe...?) and installed Elecard MPEG Decoder 2.0 and K-Lite 3.4.5 Full as per the other thread.
OS: Windows 98 SE
Reply 13 of 37, by xcomcmdr
But why convert at all ? The DVD version has an installer, and different data files anyway.
ffdshow tryouts is all-in-one, including audio codecs. K-Lite tends to wreck systems...
Reply 14 of 37, by BEEN_Nath_58
Being on the topic, does anybody have a copy of the newer DVD Express software? I used one which couldn't uninstall itself and obviously wrecked the entire MPEG2 setup
Reply 15 of 37, by DustyShinigami
xcomcmdr wrote on 2026-05-23, 06:55:
To be honest, it would be easier to track down a copy of the DVD version. Saying that though, I don’t think I’ll be able to get it to work at the moment. I lack a DVD drive. I’m going to try my brother’s portable DVD drive, though I suspect it’s going to need specific drivers, which don’t exist for 98 as it’s modern. Failing that, I’m kind of screwed at the moment. I can’t copy a DVD image to a USB either as it’ll be over 4GB. Although I could try copying the contents and see if that works.
I don’t recall having any issues yet with K-Lite.
OS: Windows 98 SE
Reply 16 of 37, by DustyShinigami
BEEN_Nath_58 wrote on 2026-05-23, 07:30:
I’m curious about this, too. I’ve not found many copies online and the latest I have managed to find is about 4.0, I think.
OS: Windows 98 SE
Reply 17 of 37, by BEEN_Nath_58
DustyShinigami wrote on 2026-05-23, 09:53:
Its better than 2.03 that I have. That version turned videos black and white
Reply 18 of 37, by xcomcmdr
DustyShinigami wrote on 2026-05-23, 09:52:
Can't you use daemon tools 3.47 and mount the dvd ISO ?
Edit: posted before reading, my bad.
Reply 19 of 37, by DustyShinigami
Okay, so far, copying the DVD files individually to my FAT32 pen drive, and from my pen drive to the 98 machine, is working. Going to break it down in stages as copying the DATA folder with everything will take it forever.
OS: Windows 98 SE
