First post, by space223
I read the readme.txt, but it isnt really clear to me on how to do so..
If anyone can help, please do!
"Whatever you do, do it 100%. When you laugh, you laugh, when you eat, you eat like it's your last meal"
uuhh i have 2 Microsoft Outlooks and none of them are working
Reply 1 of 10, by wierd_w
Must be in standard mode.
must use the patched DOSX.EXE provided
must use manually configured SNDBLAST.DRV settings in the .ini files, including the ignore irq setting.
Expect issues.
Reply 2 of 10, by space223
ah, okay, thank you! i will do that
Reply 3 of 10, by space223
wierd_w wrote on 2026-06-17, 14:15:
Must be in standard mode. must use the patched DOSX.EXE provided must use manually configured SNDBLAST.DRV settings in the .ini […]
Expect issues.
I have a quick question
where can i get sndblast.drv?
sorry if i am asking too much, i am kind of new to this...
Reply 4 of 10, by wierd_w
Basically:
1) Install win3.1
2) install and configure vsbhda normally. Use the 16bit version of the extender and driver. NOT 32bit.
3) copy the supplied dosx.exe to the windows install, and overwrite the existing one.
4) ensure sndblst.drv is present/installed.
5) manually add the information for sndblst.drv to system.ini, including 'verifyint=0'
6) make sure windows starts in standard mode.
Reply 5 of 10, by wierd_w
space223 wrote on 2026-06-17, 14:24:
I have a quick question where can i get sndblast.drv? sorry if i am asking too much, i am kind of new to this... […]
Expect issues.
The easiest way is to tell windows that you are installing a soundblaster 1.0, in the multimedia control panel, then bail on the configuration.
the config window will never detect a soundblaster when using vsbhda. But, the act of trying will unpack and install the needed files. The driver must be configured manually.
Reply 6 of 10, by space223
wierd_w wrote on 2026-06-17, 14:27:
Basically: […]
Basically:
1) Install win3.1
4) ensure sndblast.drv is present/installed.
The thing is... I do not have a sndblast.drv present, where can i get that, exactly?
Reply 7 of 10, by space223
wierd_w wrote on 2026-06-17, 14:30:
Expect issues.
oh, i did not see this, sorry
Reply 8 of 10, by space223
i will try that
Reply 9 of 10, by space223
It works now! Thank you
Reply 10 of 10, by wierd_w
Not a problem!
