Reply 20 of 67, by bitzu101
- Member
Hello all, thank you for your comments.
So... I got the Epox motherboard, it s a very high end one, nforce ultra and probably the only one of it s time with a microcode display... Wow... It also has a 4 pin cpu input so does good on power.
I have also received a 6600gt bfg gpu... And it has led... What the hell... Never seen one with an led, specially in 2003...
Good thing was that because the Asus board was nforce 2 ultra, did jot have to reinstall windows... It pretty much just works...
Must say, that I have never experienced windows 9x so snappy... It s pretty much instant... Specially because me does not have the dos background stuff loading, etc...
Now... I completely understand why you would recommend a sb live or audigy, I actually have both... An audigy în my high end p4 machine (winxp) and a live on the side... I am aware that both are more high end, have wax, etc... I have never had a aureal vortex and I just like it. Specially because is the 2. În my win 98se machine I use a ess solo 1 sound card and will not change it because of best ever card for dos compatibility....
Back to the 3200+ monster... The epox board is more stable, the power led is at full luminousity where as with the Asus board was half intensity, the board was struggling for power... 3200+ sits at 40 to 45 in idle, the chipset (repasted) is at 35.
Ram wise, I have just tried my luck... I had 512mb in dual channel and added another 256 just to try... Works great, not even the slightest issue. And the cool thing is that it still works in dual channel for the first 512mb... So no reason to go down on the ram.
I have also done a bit of cable management around the cpu and I have tried to hide most of the cables away from the cpu cooler fan... I think that is ok... If you have better suggestions, please fell free to let me know...
I have added a few pics for you...
