First post, by jami3rez
I’ve followed the steps here - https://en.m.uesp.net/wiki/Daggerfall:Running_Without_CD
But it doesn’t work, when I run the command I get the message ‘You must run dagger.exe from the hard drive’.
What should I be trying next?
Reply 1 of 2, by MasterO
jami3rez wrote on 2025-04-26, 07:00:
Daggerfall Unity is the next place you should go:
https://github.com/Interkarma/daggerfall-unity/tags
https://github.com/Interkarma/daggerfall-unit … aggerfall-unity
https://github.com/Interkarma/daggerfall-unit … -Cross-Platform
Reply 2 of 2, by wierd_w
Daggerfall checks that mscdex is loaded, and then checks for the correct volume name. That's it.
It's easy to use disc images.
