First post, by jami3rez
I’ve followed the steps here - https://en.m.uesp.net/wiki/Daggerfall:Running_Without_CD
But it doesn’t work, when I run the command I get the message ‘You must run dagger.exe from the hard drive’.
What should I be trying next?
Reply 1 of 3, by MasterO
jami3rez wrote on 2025-04-26, 07:00:
Daggerfall Unity is the next place you should go:
https://github.com/Interkarma/daggerfall-unity/tags
https://github.com/Interkarma/daggerfall-unit … aggerfall-unity
https://github.com/Interkarma/daggerfall-unit … -Cross-Platform
Reply 2 of 3, by wierd_w
Daggerfall checks that mscdex is loaded, and then checks for the correct volume name. That's it.
It's easy to use disc images.
Reply 3 of 3, by DracoNihil
Did you follow absolutely everything to the letter in that? Because after copying stuff that the installer doesn't install to the drive and then changing various paths around in the Z.CFG and then running FALL.EXE Z.CFG it never asks for the CD. Do NOT run DAGGER.EXE!
the path and pathCD need to be set accordingly to the exact full path where the ARENA2 directory was:
type dfall_huge
path C:\dagger\arena2\
pathCD C:\dagger\arena2\
fadecolor 0
mapfile d
rendergame 1
user 1
startMap 179
region 17
helmet 0
maxSpeed 200
controls betaplyr.dat
maps mapsave.sav
CHEATMODE 1
― Κυνικός Δράκων
