Reply 640 of 659, by dizzydevil
Yes, the file is correct, this is what I need!
Thank you very much!
dizzydevil wrote on 2021-07-10, 07:13:Yes, the file is correct, this is what I need!
Awesome!👍
On what page did this change to any hardware instead of period correct hardware?
Today I slotted a "new" Quadro FX 4500 in Super G5 and did some benchmarking with Quake 3, Quake 4, Doom 3, UT2004, and Prey.
Here's the Doom 3 result. Keep in mind that, unlike the PC version, Doom3 for Mac only uses a single core. Plus, it's one of the worst ports ever. Aspyr didn't even *try* to optimize this game for PowerPC. To get an idea of just how sloppy it is, consider this: Quake 4 actually runs at a higher frame rate on this machine!
PowerMac G5 Quad: 2x dual-core PowerPC 970MPs at 2.5GHz, 16 GB DDR2-533, Quadro FX 4500 PCIe, OS X 10.5.8
1024x768 Ultra:
The G5 is nearly three times faster than the G4, which at 1.5GHz w/ a 7800GS AGP, only manages 27 fps!
"A little sign-in here, a touch of WiFi there..."
Built a new living room PC but it temporarily has my old 1080ti in it for now.
Anything goes toplist
828.36, DosFreak, 7950x@4.5 GHz,ASUS ROG Crosshair x670E Gene,32GB DDR5 6000Mhz CAS 30,ASUS ROG GeForce GTX 1080 Ti 517.48, Realtek, 11x64 22H2
Doom 3 v1.0
Won't be too long before we hit 1k!
Hello,
Want to add stats for a single module trinity APU, usinng integrated Terascale 3 graphics:
AMD A6-5400K APU, Gigabyte F2-A55M-HD2, 4GB 2 x2GB GSKILL 2133 DDR3 F31700CL9D-4GBXL CL9-11-9-26 1.6V. SO: Windows XP SP3.
Stock CPU@3.6GHz & GPU@760MHz clocks, 1600MHZ DDR3 speed: 65,7FPS
CPU@4,4GHz, GPU@1024MHz, XMP 2133 DDR3 speed: 83,2FPS
It's nice to see more results added.
I have not given up on this project and the new results will be added to the list sooner or later but not in this instant as I'm on a low res screen.
Perfect score 😁
^NV build-in audio (since MB one doesn't have drivers for XP)
EDIT : 666.5, agent_x007, 5800X3D@4.55 GHz, Gigabyte B550 Aorus Pro v2, 32GB DDR4 3800MHz CAS 14, ASUS GTX Titan X 368.81, NvIdia (build-in audio), XPx86 SP3, Doom 3 v1.0
agent_x007 wrote on 2023-11-26, 02:28:Perfect score :D https://www.vogons.org/download/file.php?id=179424&mode=view ^NV build-in audio (since MB one doesn't have driv […]
Perfect score 😁
^NV build-in audio (since MB one doesn't have drivers for XP)EDIT : 666.5, agent_x007, 5800X3D@4.55 GHz, Gigabyte B550 Aorus Pro v2, 32GB DDR4 3800MHz CAS 14, ASUS GTX Titan X 368.81, NvIdia (build-in audio), XPx86 SP3, Doom 3 v1.0
Hahaha, indeed, the perfect score for Doom 😀
Will try to contribute to this thread sometime soon.
Newest: Intel i5 10400F / Asus B460M-CSM / Intel ARC770 LE 16GB / 32GB DDR4 Kingston / Win 10 64
Oldish: Intel i7 3770 / Gigabyte GA-B75M-D3H / Quadro K620 2GB / 16GB DDR3 Kingston / Win 7 64
Older: loading... WinXP32?
Oldest: loading... Win98SE?
I have read this thread and I could not found a clear answer to the question: Doom 3 requires SSE or not?
I have a system with Thunderbird 1400C and will not run Doom 3; however if I replace the CPU with the XP 1500 the game will run! So it would appear that Doom 3 needs SSE.
However Phil in Intel vs AMD S2E3 clearly has Doom 3 running on the 1400C with no problems and even has results with various video cards!
How is this even possible?
nd22 wrote on 2024-10-06, 06:09:Doom 3 requires SSE or not?
Doesn't. it's quake4 that requires SSE (and will politely break if it doesn't find the extension)
Though I have not played Doom3 on a SSE-less machine after it had some patches... but around release it didn't require SSE.
Debian's fucked
I have Doom 3 and RoE installed with the latest 1.31 patch. The game will not start with an Athlon 1400C. I should mention that when you install RoE it will automatically update the game to version 1.2.
From that moment the game will NO longer run on the T-bird 1400.
Tested by me a few minutes ago on the following system:
Athlon 1400C, 2x1gb ram, Abit AN7, geforce 7600GT, WD 150GB.
What is odd for a game that does not require SSE is the Athlon XP 1500 mentioned in the MSR file.
Unfortunately I dont have any functioning retro builds at the minute. However, I was curious, do any of the doom 3 source ports work on retro hardware and older OS's? I wonder how they perform vs the original engine...
I don't know about hardware but here is OS:
XP
dhewm3_1.5.1pre1_win32 (Change t0 4.0 in CFF Explorer)
Vista
dhewm3_1.5.2_win32
RBDOOM-3-BFG-win32-20140510-git-14f87fe
2000BWC/XP
fhDOOM-1.5.2-1414 (Change to 4.0 in CFF Explorer)
uqe_doom3_132 (Might need to change to 4.0 in CFF Explorer)
8+
RBDOOM-3-BFG-1.4.0.9-lite-win64-20220306-git-f81a8c1
DosFreak wrote on 2024-10-09, 10:47:(Change t0 4.0 in CFF Explorer)
Could you explain how to do this? I found the attribute subsystem in CFF Explorer but I can't change it to 4 only 1,2,3,5,... .
I strugle too to get doom3 working on my XP Machine, I tried loading the source port version from fhdoom and dhewm3 from the vogonsorg github page, replaced the exe file with the one from the release section, tried to modify exe in CFF Explorer but nothing seems to work. I use the pk4 files from my steam installation off doom3 if this makes any difference.
For MajorOperatingSystem and MajorSubsystem change the values to 004. For accuracy for XP you can change Major to 5 and minor to 1 for XP but I prefer to not having to constantly modify files for different Windows versions if I don't have to.
Only dhewm3 v1.5.1pre and fhDoom 1.5.2-1414 and earlier will work on vanilla XP.
You can probably just run PatchPE instead but I've never bothered with it, a lot of times these tools only run on newer versions of Windows.
apfel wrote on 2024-11-19, 07:11:DosFreak wrote on 2024-10-09, 10:47:(Change t0 4.0 in CFF Explorer)
Just FYI, with dhewm 1.5.0 you don't need to change anything, since that version still have PE headers set to 5.1, which is Windows XP.
Pentium 4 2.4GHz (Northwood) @ 3.03GHz (168x18), ABIT BH7, 1GB DDR420 2.5-3-3-7, Radeon 9800 (400/580), Audigy 2 ZS, XP-SP3
1024x768 Ultra - 33,6 FPS
Athlon 64 3200+ @ 2.32GHz (232x10), MSI K8N NEO, 1GB DDR 464 2.5-4-4-8, Radeon X850XT (CATALYST 10.2), X-FI, XP-SP3
1024X768 Ultra - 86,9FPS
Did some tests on my setup. Had no idea the 1.3.1 patch actually made the game slower. Tested the game with the patch and without. Also before overclocking the card and overclocking. I think the overclock might be producing some weird and random squeaking via my speakers...? Perhaps some form of coil whine/ground loop issue...?
I'm not quite sure about some of the details for this. Especially concerning the numbers in brackets for the RAM.
Pentium 4 2.4GHz (Northwood) @ 3.20GHz (not sure about this part), Asrock P4i65G, 512MB DDR400 (not sure about this part. Also have yet to try 1GB and playing the game from an SSD), Inno3D Geforce 6800 GT 256MB (400/1.04GHz), Creative Sound Blaster Live! Value (CT4670), XP-SP2
With the 1.3.1 patch:
48.5fps - 640x480
48.6fps - 800x600
48.1fps - 1024x768
Version 1.0:
51.4fps - 1024x768
800x600 gave me the same results. Didn't bother testing 640x480. Also, I never noticed the timedemo produce so many pauses when I first played the game and ran the benchmark test. Running it a second time all the pauses disappear. I'm guessing running the game from an SSD would eliminate these pauses...?
OS: Windows 98 SE
CPU: Slot 1 Pentium III Coppermine 933MHz (SL448)
RAM: Kingston 256MB 133MHz
GPU: Nvidia 16MB Riva TNT/128MB Geforce 4 Ti 4200
Motherboard: ABit AB-BE6-II Intel 440BX
Sound Card: Sound Blaster Live Value CT4670
