DoxBox 0.72 & Vista x64 & Laptop & Pascal
General information and assistance with DOSBox.
Postby Ok-Alex » 2008-10-21 @ 15:14
Please help me.
I'am using Borland Pascal in Vista x64 via DoxBox 0.72.
Everything working good, but I have one problem with keyboard.
Some keys don't work in Pascal, some show me wrong symbol.
For example :
When I'am trying to input ' nothing happens.
When I'am tring to input \ wrong symbol appeard [
When I press [ nothing happens..
Sorry for my bad english.I hope you'll help me :)
P.S.: My config in signature..
HP dv4t :
Core 2 Duo P8400 2.26 Ghz
Nvidia GeForce 9200M GS 256mb
2x2048gb RAM 533 Mhz
Display resolutin 1280x800
Windows Vista x64 Ultimate.
Ok-Alex
Re: DoxBox 0.72 & Vista x64 & Laptop & Pascal
Postby wd » 2008-10-21 @ 15:45
Check the keyboard layout stuff (readme).
wd
DOSBox Author
Postby Ok-Alex » 2008-10-21 @ 15:54
Sorry I dno't understand.
I tried to swith keyboard layot to US,USA,UK,SP,SV,RU but it's didn't helped me.
Maybe I'am doing something wrong???
HP dv4t :
Ok-Alex
Postby wd » 2008-10-21 @ 16:07
Well don't know what you expect exactly, by default the keyboard layout
is us (english) as that's how every pc works. Usually the backslash \ is
on one of the keys left to the return key, can you find that?
wd
DOSBox Author
Postby Ok-Alex » 2008-10-21 @ 17:18
Here is my keyboard.Any suggestions?
HP dv4t :
Ok-Alex
Postby wd » 2008-10-21 @ 17:23
Any suggestions?
Start up dosbox and hit those keys left of the return key, if none of them
produces the \ key try some others. If you can't produce the \ at all something
general is wrong.
If you can produce it somehow, you'll just need to deal with the layouts.
wd
DOSBox Author
Postby Ok-Alex » 2008-10-21 @ 18:08
In registry I found that my default system layot is 866.
How to setup it in DoxBox?
HP dv4t :
Ok-Alex
Postby Ok-Alex » 2008-10-21 @ 18:15
In readme there is the link http://projects.freedos.net/keyb/ is dead.
I don't know what to do else.
When I press backslash it's return me ]
When I press ] it's return me [
When I press = it's return me nothing
When I press ' its return me nothing
HP dv4t :
Ok-Alex
Postby wd » 2008-10-21 @ 18:35
As already noted a few times, you FIRST have to get the ENGLISH layout
to work at all. IF it works, then you can switch the layout to fit what is
printed on your physical keys. If you don't get the english layout to work,
the layout switching won't work at all, this is also true for freedos keyb
so don't bother with that yet.
Make sure that you can edit the dosbox.conf file (re-open it after you changed
it so you see that the values actually were saved) and set usescancodes=false
(it's true by default).
wd
DOSBox Author
Postby Ok-Alex » 2008-10-21 @ 21:18
I pressed every button of my keyboard.I can't produce \ .
HP dv4t :
Ok-Alex
Postby Ok-Alex » 2008-10-21 @ 21:20
Maybe it's not work because of MULTIMEDIA KEYS?
HP dv4t :
Ok-Alex
Postby wd » 2008-10-21 @ 21:30
did you try the usescancodes setting?
wd
DOSBox Author
Postby Ok-Alex » 2008-10-21 @ 21:34
Yes.
Here is a part of my conf
Code: Select all
fullscreen=false
fulldouble=false
fullresolution=640x480
windowresolution=800x600
output=surface
autolock=true
sensitivity=100
waitonerror=true
priority=higher,normal
mapperfile=mapper.txt
usescancodes=false
HP dv4t :
Ok-Alex
Postby wd » 2008-10-22 @ 06:31
When running dosbox type "usescancodes" to check if the value was accepted
(ie. the correct dosbox.conf was changed).
wd
DOSBox Author
Postby Ok-Alex » 2008-10-22 @ 07:47
x:\downloads\tp\bin>usescancodes
false
HP dv4t :
Ok-Alex
Postby Ok-Alex » 2008-10-26 @ 10:21
Any more suggestions?
HP dv4t :
Ok-Alex
Postby wd » 2008-10-26 @ 18:26
Nope, because i don't have anything to test weird keyboards with.
Updating graphics drivers/directx might or might not help, same for windib
sdl interface (search the forum for that one) and similar stuff.
wd
DOSBox Author
Postby odie4bre » 2008-10-27 @ 03:14
I am having this same problem and I have a basic desktop keyboard. I have tried everything you have suggested to no avail. If anyone can help, it would be very appriciated.
odie4bre
Postby wd » 2008-10-27 @ 10:23
system specs? exact OS version?
wd
DOSBox Author
Postby odie4bre » 2008-10-27 @ 18:03
I am running Vista and have found the solution.
Here is where I found it.... http://www.dosbox.com/wiki/FAQ
Q. My backslash key is mapped to ']' with DOSBox in Vista. Is there a workaround?
A. Press CTRL-F1 to enter the keymapper and select the backslash with your mouse. Press the DELETE button that will show up on your screen. Then press ADD to bind backslash to another key. Simply press an unused key to bind it to this. Press SAVE and then EXIT to return to the main screen.
odie4bre
Next
Return to DOSBox General
Who is online
Users browsing this forum: MSN [Bot] and 1 guest
