First post, by SlowA
- Newbie
1. Abit NF7-S
1.1. Mantaray XT BIOS flash
The board is very unstable when running DDR400 in dual channel. I've tried different DIMM slot combinations, and so far slots 1 & 3 seem to be more stable than 2 & 3. Single-channel mode works fine at DDR400.
I've tried:
Different memory voltages (2.6V–2.9V)
Different RAM modules (BH5, Infineon BE-5, CE-5, Hynix D43)
Different CPUs (Athlon XP 2800+ Barton, Mobile Barton 2400+, Mobile Barton 2500+)
Two different power supplies
Nothing has solved the unstability issue.
1.2. No onboard audio
The onboard audio doesn't work at all on any of the audio outputs. The BIOS detects everything correctly, and Windows XP SP3 also reports that the audio hardware is working properly, but there is no sound.
2. ASUS A7N8X Rev. 2.0
The board was working properly, although all of the options under Advanced (CPU/FSB/RAM/Voltage) were greyed out.
After a successful BIOS flash (confirmed), the board refuses to power on properly. I've reflashed the BIOS chip six times using a programmer (four official ASUS BIOS versions and two modded BIOS versions).
The board receives power, but there is no POST.
