Reply 80 of 90, by Intel486dx33
Nice assortment of cards.
It was a Magical time back around the release of Win95
Between 1993-97
Huge assortment of motherboards, cards, and AT cases
Were available back then.
Windows 95 was developed to support the 486dx-33 CPU.
Runs best with at least 8mb of ram, 4x cdrom, sound blaster 16, and
1mb SVGA video card. 3com 3c509c-combo network card.
Plug and play installation with Win3x or Win95
From my experience Win95 is the Best OS for the 486 CPU
And old ISA/VLB hardware
Reply 81 of 90, by Jo22
^I agree with that. 😃
.. except for Windows 95 itself. I have mixed feelings about it.
Windows 95 RTM was buggy, but it had positive things, too.
The blue Setup wallpaper and the welcome melody, the network drivers, auto detect etc.
But Windows 95 also moved everything away from Windows 3.1x era and introduced DirectX,
which ended DOS gaming era. It took away the MIDI Mapper of Windows 3.x etc.
And I didn't like that, it was moving away from that pioneering 1990-1994 computing world
of a Sega Genesis/Sega CD, 3DO, Kodak PhotoCD, Philips CD-i etc and was taking everything with it.
Again, I have mixed feelings here. Windows 95 was a transitional time between 16<>32Bit era.
It still was mostly running 16-Bit software, but focussed on Win32.
Visual Basic 3 was still common during Win 95 times, for example.
Windows 95 was a bridge for legacy networks, too.
It could use an existing DOS network software and then load a Windows network driver and make them both talk to each others.
With Windows 95, the number of novice computer users increased dramatically, too.
By the time Windows 98/98SE came out, it was a mostly 32-Bit computing world.
Reply 82 of 90, by Disruptor
Jo22 wrote on 2026-07-16, 21:59:
But Windows 95 also moved everything away from Windows 3.1x era...
It took away the MIDI Mapper of Windows 3.x ...
No that is not true. MIDI Mapper was still available and you could assign each of the 16 channels to a different sound card.
That was removed in the NT based Windows operating systems.
Reply 83 of 90, by Jo22
Disruptor wrote on 2026-07-16, 22:28:
The gradual death of the Microsoft MIDI Mapper (translation)
Edit: Perhaps it was more accurate if I said Windows 4..
Windows NT 3.x apparently still has the traditional MIDI mapper, too, just like normal Windows 3.1x has.
Windows NT 4 has it changed, comparably to Windows 95 (aka Windows 4.0).
Edit: Windows 3.0 MME has a MIDI Mapper, too, but I have little experience with MME.
Reply 84 of 90, by Irinikus
Intel486dx33 wrote on 2026-07-16, 00:06:
Nice assortment of cards. […]
Between 1993-97
Thanks! (It should hopefully be pretty interesting!)
That was indeed a great time.
I intend to get a 2.1GB Quantum Fireball for the machine which I'll dual partition to have Dos and Windows 3.1 on one partition and Windows 95 on the other.
YouTube
Reply 85 of 90, by Irinikus
The Pentium Overdrive has arrived from Japan:
And the VLB Ethernet card has arrived from Poland:
YouTube
Reply 86 of 90, by Irinikus
All of the parts for the 486 upgrade have arrived! (I’ll install them into the machine in the next month or so, when I’m in Cape Town.)
So there’s the Pentium Overdrive, 128MB of registered FPM RAM, 512KB 15ns cache, 8MB of FPM RAM for the Gravis Ultrasound PnP, ISA TV/Capture Card and the VLB Network Card.
YouTube
Reply 87 of 90, by zapbuzz
Irinikus wrote on 2024-07-22, 11:03:
Anonymous Coward wrote on 2024-07-21, 14:59:
Maybe I missed something, but I didn't see any mention of 64kb cache. At least according to the pictures provided there is 0kb cache.
Going from 0kb to anything would yield a very significant improvement (more than 3%).
I Agree!
I'll put in 256K cache as well as a Pentium Overdrive 83MHz chip.
The Overdrive 100 is literally identical to your DX4 100 in silicon and real world performance also you are replacing a 100 with an 85?
If your motherboard already native-supports a standard DX4-100 (providing the right voltage), an OverDrive chip offers zero performance benefits. You would only use an OverDrive processor if your motherboard is restricted to older 5V CPUs and lacks native 3.3V support.
Reply 88 of 90, by Law212
Nice looking machine, but it needs a nice crt to go with it IMO
Reply 89 of 90, by Irinikus
Law212 wrote on Yesterday, 15:55:
I'm going to track down a period specific IBM CRT Monitor for it.
YouTube
Reply 90 of 90, by Irinikus
zapbuzz wrote on Yesterday, 15:53:
I Agree!
According to these test results, the Pentium Overdrive, even running @ 83MHz is significantly more powerful than a 486DX4 100, especially when it comes to floating point performance demonstrated in game like Quake! (I'm going to attempt to clock this one @ 100MHz)
The Pentium Overdrive chip is also more collectable than a straight 486 DX4 100 chip.
YouTube
