Reply 2660 of 2714, by Falcosoft
- l33t
zaphod77 wrote on 2026-09-05, 16:05:So we still need vst midi driver to mix 64 and 32 bit plugins, while we can directly use sc va and 64 bit clap plugins in 64 bit player, and everything else needs 32 bit player, right?
If you have JBridge 1.76+ then you can use 32-bit plugins also with the 64-bit version of FSMP. E.g. S-YXG50 works perfectly.
Support for JBridge is integrated into my fork of BASS_VST so no wrappers/renamed dll files are required. If you have JBridge v1.76+ installed you can load the 32-bit VSTi dll files directly from 64-bit FSMP.
