D-Fend Reloaded (DOSBox frontend)
Reply 2280 of 2284, by IIGS_User
breshar wrote on 2024-02-13, 18:41:
I use D-Fend Reloaded 1.4.4 for quite a while now. I've added about 400+ entries, also making separate entries for modded games like Commander Keen or Doom.
This version of D-Fend Reloaded is outdated, and ScummVM probably changed the file format, so D-Fend Reloaded doesn't know how to read it.
Klimawandel.
Reply 2281 of 2284, by Ohrensessel
just was strolling through the forum yesterday to see if there are any new interesting posts and stumbled across the D-fend Reloaded thread and saw that people complain that Dosbox-X is not really supported in D-fend Reloaded. I am using Dfend Reloaded since a lot of years. Unfortunately I started with my games database (way more than 1000 games and software until now) before development of D-fend Reloaded ended, so I am now stuck with it. On the other hand it worked flawlessly until now, even with Dosbox-X. Just had to add a new Dosbox installation under Program options, point to the Dosbox-X folder and rename the exe from dosbox-x.exe to dosbox.exe. Any additional settings (like for example for MT32, used soundfonts or printing) can then be added in the "Custom settings" field under "Dosbox settings", though I have never tried Voodoo support until now. So I never had the need to even touch the dosbox-x.conf file. Just lately I had a problem with the Z drive path (Z:\;Z:\SYSTEM;Z:\BIN;Z:\DOS;Z:\4DOS;Z:\DEBUG;Z:\TEXTUTIL). Seems with newer versions of Dosbox-X the path needs to be added by hand in the DOS environment settings of D-fend Reloaded.
Maybe someone finds this helpful.
Ohrensessel
Reply 2282 of 2284, by rico001
IIGS_User wrote on 2024-02-13, 19:05:
I was thinking of renaming Dosbox-x to dosbox and having it for defend reloaded too today. Some other ideas today were add support for qbasic and/or basic-a wizards... basic-a was provided in a botched MIT license release by Microsoft releasing msdos 4.01. For 2026-1 January so far Dosbox-X has many new features... You may have to create a new config file for it, backing up your old one first.
Reply 2283 of 2284, by zapbuzz
Hi, I was looking at this frontend and think gee this would be good in Windows Millennium so I don't have to use the command line in DosbBox all the time.
There's nothing about system requirements for it.
Its funny how AI says run millennium in DosBox-X but doesn't talk about DosBox in Millennium itself. (I see no benefit except a toy)
DosBox is useful in Millennium as it has no dos mode. Even though its not supported.
Reply 2284 of 2284, by Estel Randir
I tried the dosbox-x method of renaming the .exe to dosbox.exe and the .conf to dosbox.conf. I got window mode to work, but fullscreen does not work well at all. Dosbox-x uses a different method of scaling. It does not stretch. When I go to fullscreen, it turns to just garbled lines and colors. Dosbox staging does not work at all.
