Ydee wrote on Today, 07:49:
Okay I installed this and seemed to work better. Volume was much louder and now MIDI outputs by the synthesizer instead of wave control. Now games sound under win98, but only wave effects, nor synth (music) so I have jumps and so but NO music.
I had 2 installs, one with only files (attached) and other with this and some more files and a program installer. I installed "manually" by the device manager, nor by the installer.
The supossedly "DOS" folder inside this is in fact a OS/2 driver, so It don't features DOS drivers or i've unknown the way to install it. I really don't know how to install this card under dos. Need a clear explanation of it.
Installed then CrystalWave Synthetisher that comes in the w98 installer I attached. Supposed it could be some kind of midi-translator to it's own way to make the job. It did nothing-
Then I went to the folder you sent me, ran the installer and got BSOD on each startup. Now im reinstalling W98 from zero.
Every restart is tedious even more in this board with no memory skipping. I'm spending all weekends on this, and reached a new dimension of headache-.
I attach also a game i'm using to test.
