gsos wrote on Today, 01:38:
Okay I released a new version that might fix the issue (tentatively). Likely APIC didn't route the PIC irqs. There will be new log lines if it still doesn't work
Ok, it finally works, tanks. 😁
But this time a lot of additional consideration needs to be added:
Modes:
It boots both in UEFI, native CSM and CSMWrap
In UEFI I got the 4/3 aspect ratio, with fonts scaled according the 1440x900 native resolution ( practically 1200x900) in not that pleasant way
In CSM --> native video bios mode, the screen is scaled to 1440x900 (so stretched to 16/10) but with very nice looking smoothed fonts
In CSM --> VBE mode , same as above, with smoothed fonts, but not nice looking as above
The strangest part is that if I use the VBE mode AND persistent disk, I have no keyboard (I can't see the relationship, but that's what happens)
Programs:
VC 4.05 works
VC 4.99 --> too big to fit in memory (not yet tried to set it as default boot program)
MC --> bad filename or executable something like that, (from the log, setting it on boot: "Windows PE exec failed (home/retroos/CONFIG/MC/MC.EXE): errno 2")
Everything else I tried seem working OK
Other issues:
My second USB keyboard (which is what I'd like to use normally) is still non functional (albeit it's illuminated, so somewhat detected and enabled but not initialized correctly)
I see correctly my partitions, but as I wrote before I cant see the games bundled in the downloaded images.
Intel N100:
not yet tested.
