First post, by zuldan
Got this beautiful card today. Unfortunately, it's got memory issues. Going to start by checking resistors on the back of the card. I hope the core is not gone 🙁
The attachment 20261006_161508.jpg is no longer available
The attachment MATS.png is no longer available
The attachment Front.jpg is no longer available
The attachment Rear.jpg is no longer available
Reply 1 of 5, by Trashbytes
Looks like a bad memory IC or possibly it needs the memory ICs reflowed, the heat sinks complicate it a bit.
Reply 2 of 5, by zuldan
Trashbytes wrote on Today, 07:09:
Those heatsinks look like a nightmare to remove 😗 Will try the twist method first.
Still testing resistors. Best case scenario, bank 0 has lost power (not sure where to check voltages). Or something has gone wrong with the core.
Reply 3 of 5, by Trashbytes
zuldan wrote on Today, 11:14:
Use some canned air, tip the can upside down and freeze the heat sinks with it, it will make the thermal bonding brittle, will help to reduce any further damage from trying to remove them.
The MATS test looks like it can detect the bank so unlikely its lost power .. check the data lines perhaps a data pin is lose.
Reply 4 of 5, by tehsiggi
Either hot or cold.. I use 100°C warm hotair - let it soak the heatsink a little and then gently twist them. Worked for me so far every time without issues.
I'll check my archives later if I have a schematic laying around somewhere.
AGP Card Real Power Consumption
AGP Power monitor - diagnostic hardware tool
Graphics card repair collection
Reply 5 of 5, by zuldan
Thank you both for the tip!
@tehsiggi that would be amazing if you had the schematics.
Look what I found
The attachment IMG_0479.jpeg is no longer available
