First post, by BussardRamjet
Compiles natively to Windows/MacOS/Linux and also WebAssembly.
Supports adding seams based on (CS:IP) so one can make enhancements as desired.
Emulator fully open source: https://github.com/amberfolio/amberfolio
It only runs Pool of Radiance yet - but it has full screen reader support (text as well as the scene), gamepad support, modernized controls, etc.
Give it a try if you are interested! https://amberfolio.org/
Disclaimer - Gen AI was used to build both this. Without it, none of it would exist.
