First post, by BussardRamjet
Compiles natively to Windows/MacOS/Linux and also WebAssembly.
Supports adding seams based on (CS:IP) so one can make enhancements as desired.
Emulator fully open source: https://github.com/amberfolio/amberfolio
It only runs Pool of Radiance yet - but it has full screen reader support (text as well as the scene), gamepad support, modernized controls, etc.
Give it a try if you are interested! https://amberfolio.org/
Disclaimer - Gen AI was used to build both this. Without it, none of it would exist.
Reply 1 of 2, by BussardRamjet
The emulator reached 1.0 (first full release); Pool of Radiance end to end!
A bunch of things were added to make sure it plays really well on modern PCs. (text delay, etc.)
Please check out the trailer: https://www.youtube.com/watch?v=Ev-IouRss2s
Reply 2 of 2, by gerry
its cool, and good of you to note AI role
would people not play these games i dosbox either locally or in browser?
in fact, isnt this a bit of a dos emulation software with ssi in mind?
