bitslasher wrote on 2026-11-01, 17:00:That's a valid point! I had originally considered this, but the lack of standardization around those power bricks discouraged m […]
rmay635703 wrote on 2026-10-31, 16:49:
Tons of 19.x volt laptop psus are made into waste every year, needing 12v specifically leaves a ton of donar equipment be it classic 19 volt barrel or USBC which could plug externally to fire up the internal PSU bits
That's a valid point! I had originally considered this, but the lack of standardization around those power bricks discouraged me. The voltages, the amount of power they put out, the type of jack that it has... it's all over the place. I was attempting to at least at first come up with the simplest most generally useful components, like the DC converter part.
So the high-voltage part of the design at the moment is placed on a pre-made AC/DC 12V internally installable unit. There can see a variation of this design that can adapt to a barrel though. So let's say one could have in place of the AC/DC module another smaller module that adapts the 19V down to 12V. Then one could replace the C14 AC plug on original PSU with a 3D printed component that houses a barrel jack to accept the external PS.
Is there a way to make something that can auto-sense the incoming voltage and regulate it down to 12V? And as for the barrels, is there a "generic" barrel form factor that is easy to find adapters for?
You have to consider complexity. If you want to be universal, it has it's price.
That's why I asked the questions on what you wanna achieve with the design. Internal or external power supply etc.
And if you want to "auto-detect" if the input are 19V instead of 12V, you'd have to have an additional step down from 19V to 12V.
If you consider this, you should directly chose 24V for the input voltage, even from the AC/DC part. Then using 19V instead is a breeze. You can then go from 24V to everything else.
For your design: I'd go with angled connectors so the module can stand vertically. This helps to use space more efficient.
Why would you go directly with the 12V into the module? Why not into the backplane and from there via the single connector to the DC/DC part?
Those pin headers are, depending on the manufacturer, rated with around 3A per pin. I'd not exceed 1,5A or 2A per pin.
Which then begs the question, how much output current do you want to transfer from the DC/DC boards per rail? 20A-30A per output voltage? (the 3.3V and 5V)
That would mean (if you go with 3A) up to 10pins per rail (when going for 30A) + 10 corresponding GND return pins per rail (because the current has to come back.
That doesn't leave much on the 40 pins.
What is your desired power rating? I've written a lot of questions in the previous posts for which we still seek answers 😉
Do you have some kicad files to review? some traces look interestingly thin 😁
