DFendX - the legend is reborn (again)
Reply 120 of 131, by kolderman
dosmax wrote on 2026-11-10, 11:53:
DOnt't worry, I just miss my custom resolutions and cycles settings. 😀
Not at all, and custom values for some fields in a different way might be a worthy addition, I'll add that to the backlog 😀
Interesting about the staging/glide issue - which version of staging are you using? DFendX makes a distinction between older versions and newer versions, as DOSBox staging had a large rewrite around the 0.82 release. Maybe try the latest version and see if it still occurs?
Reply 121 of 131, by dosmax
Maybe you could at least add more 16:10 resolutions. A few are present, but some important ones are missing (640x400, 960x600, 1280x800, 1600x1000). There are tons of DOS games that - while most of us played them in 4:3 back in the day - actually only look correct aspect ratio wise when displayed in 16:10. Many 320x200 games have an 1:1 pixel aspect ratio and thus look vertically stretched at 4:3.
DosBox Staging 0.83 indeed solves the Glide page mystery. I'm currently stuck with 0.82.2 since 0.83 broke some "important" games for me. Should have tried that right away... The only actual glitch is the 'Glide Emulation/emu' list entry. I believe Staging currently only has on/off unless I'm mistaken. Doesn't really matter though. Consider that one closed.
Reply 122 of 131, by kolderman
dosmax wrote on 2026-11-10, 19:57:
That sounds reasonable. I will look at adding that in the next release. As for the emu entry, DFendX output the correct values for staging (true) even though the combo value emu is not valid for staging. I might look at gating that for staging in future too. Cheers
Reply 123 of 131, by kolderman
AlfreX wrote on 2026-11-08, 13:01:
It's great to wake up and see a new release! Are all these improvements—and the previous ones—included in the Linux version I'm […]
Are all these improvements—and the previous ones—included in the Linux version I'm testing? I'm asking because my executable says DFendX-2.6.3.
I’d like to take this opportunity to report a few minor issues I’ve found.
1) When editing a profile, in the “Drive” section—specifically, the CD/floppy/etc. mount settings—the arrows for moving forward, up, and back are too dark on a dark color scheme like the one I use, making them hard to see. Maybe you could change them to green.
The attachment arrows.jpg is no longer available
2) When you have a profile selected in the cover view, you're editing it, and you select an image as the default cover for it, the grid jumps up about three lines when it refreshes, causing you to lose sight of the game you were editing, and you
have to scroll back up with the mouse wheel if you want to see how it looks or continue working on it.
To be honest, these are just little things that affect quality of life but aren't very important; I'm mentioning them because I couldn't find anything more important
Hi, I have a new build. It covers a few things:
- the changes from 2.6.8 windows build have been ported to Linux.
- the cover view scroll jump has been fixed (also preserves the mouse scroll sensitivity option after these kind of refreshes).
- more consistent styling between different linux QT themes (e.g. Fusion vs Breeze).
The Drive file selector arrow issue was not fixed as it's outside of DFendX - it's the system file picker. You might be able to adjust the desktop theme of your Linux to control that.
Cheers
https://send.bitwarden.com/#wMR3qRw7lkanRLUCA … MTLwDBwKEQNNnNg
Reply 124 of 131, by AlfreX
TY for the update! At a quick glance, everything works great! When I have more time, I'll test it thoroughly and let you know if I find anything.
Reply 125 of 131, by AlfreX
Reporting here!
1) When I select any view mode other than screenshots or cover art, this error appears.
The attachment lis view or icon view.jpg is no longer available
2) In the “Profiles” section, the option to search for games in GamesDB—or any of the other options—doesn’t work; nothing happens when I click on them.
3) I finished adding my entire game collection to DFendX, but I can’t find the option to back up the profiles.
4) In the Help section, except for the “About” option, none of the other options work (Check for Updates, Help, etc.).
Remember I am under Linux
Thanks for everything, and keep up the good work!
Reply 126 of 131, by kolderman
AlfreX wrote on Yesterday, 01:05:
Reporting here! […]
Reporting here!
1) I can't reproduce that with my setup. Is there a chance you could zip up your profiles directory (with all the .prof files) and add them to a reply here?
2) This has not been implemented at all yet in Linux. Something for the future.
3) Are you referring to a specific option in the Windows version that is missing? Or is this a new feature you would like to see implemented?
4) The help popup has not been worked on yet. Again, something for the future.
Cheers
Reply 128 of 131, by AlfreX
1) Sure, here it is. The error occurs in all view modes except “Cover” and “Screenshots.” (Even if this error window pops up, if you click “OK,” the selected view mode loads normally.)
The attachment profile configs.zip is no longer available
* Another thing I noticed is that, in addition to the error message, if I click “OK,” the view mode changes, but it doesn't load the complete list of profiles. For example, in this image, you can see that it only goes up to the letter L (my complete list goes all the way to Z).
The attachment list.jpg is no longer available
2) OK
3) Sorry, maybe it was my mistake. I thought there was an option to back up my game collection profiles and settings. If not, I suggest adding that feature; I think it would be quite useful.
4) OK
*** A new bug I noticed in the latest version for Linux is that when editing a profile, the window colors don't match the theme (in my case, Dark Brisa). This didn't happen in the previous version.
The attachment color.jpg is no longer available
Reply 129 of 131, by kolderman
AlfreX wrote on Yesterday, 04:53:
1) Sure, here it is. The error occurs in all view modes except “Cover” and “Screenshots.” (Even if this error window pops up, if […]
2) OK
4) OK
Thanks for sending the ZIP, I will look into it.
And when you say theme, you meaning you are setting the theme in Linux and letting it apply to the app? The reality is DFendX inherited no specific theme support, and that is something that will have to be looked at separately. I'll add it to the Todo list though.
Reply 130 of 131, by AlfreX
No, what I mean by “theme” is that in KDE Plasma, by default, you can choose between a light theme (where the windows, taskbars, and the rest of the UI are white) or a dark theme—which is what I'm using—where all the components appear in black. What I noticed is that in the latest release you gave me to test—as shown in the image I attached earlier—when I click “Edit Profile,” there’s an error that causes the window to deviate from the default dark color scheme I use, making it appear white. This didn’t happen in the previous build you gave me.
In fact, if you look at the image above, you can see that some elements do follow the dark color scheme (such as the sidebar and the buttons), but the window itself appears white.
Reply 131 of 131, by kolderman
AlfreX wrote on Yesterday, 12:57:
Got it. This was a result of trying to add more contract to the pages so things like textboxes and groupboxes stand out more. I'll guard it so it doesn't happen if the background is already dark. Expect it in the next build!
