First post, by Malik
Thought of continuing this matter here from the other (last third of the) thread "Could this be the ultimate fastest system with pure dos sound support?".
Interesting infos are also provided by Great Hierophant over here.
I have faced similar no-sound problem when using in a Socket 370 based DFI 6AC1 motherboard which has 3 ISA slots and running on a PIII 1GHz.
I have also used the card on a DFI P2BXL Slot-1 motherboard, which worked without problems. This has a PIII 450Mhz Slot-1 Processor in it.
After testing on the 6AC1, I tried back on the P2XBL, but this time there's no sound output coming out. And I don't know what happened.
Could it be that the P2XBL ran it before out of mere luck? Or did I fry my LAPC-I in that 6AC1? I doubt any static electricty would have caused it.
And no -5v means no go for the LA synthesis?
And what of this 4.77MHz thingy? What if the bios doesn't have the option to change this setting? And how does the clock setting ( 2clk,3clk etc) affect this?
And finally does it really matter when it comes to an 8-bit or 16-bit ISA slot for LAPC-I to work?
Any comments are extremely valued since this is quite a new piece of information to me.
Thanks!
Reply 1 of 18, by swaaye
My big 'ol Ensoniq Soundscape cards don't work without -5v. It's not really hard to find a -5v equipped ATX PSU. That rail is often available on the ~300W PSUs out there (just look at the PSU label for it.)
for example,
http://www.newegg.com/Product/Product.aspx?It … N82E16817152019
and
http://www.newegg.com/Product/Product.aspx?It … N82E16817182006
Reply 3 of 18, by Great Hierophant
I had an LAPC-I once upon a time ago, put it in a ASUS P2B and it worked just fine without fiddling with ISA settings. I wouldn't worry about 4.77MHz.
If no other option exists, you can use a 7905 Voltage Converter to derive -5v from -12v.
Reply 4 of 18, by retro games 100
If an ISA card requires -5v, and the PSU that you use does not supply this type of voltage, what happens? Does the PC fail to boot? Or does the ISA card in question not function correctly?
Thanks.
Reply 5 of 18, by Malik
Fair enough.
I just changed the PSU which has a -5v output and now the LAPC-I works!(Thanks, swaaye & Great Hierophant).
This is the fastest ISA based system that I have tested the LAPC-I on :
DFI 6AC1 Motherboard
256MB PC133 RAM,
1GHz PIII CPU (Socket 370)
AWE32 3980,
S3 ViRGE,
Voodoo2,
Geforce4 Ti4200
So far, from what I've found out, it's only the -5v which renders the LA portion impotent. Previously, I was of the impression that the -5v has something to do with the ISA slot or the motherboard make which has some sort of -5v channel line supplying it in-situ. Thanks to swaaye, I came to know the problem was with the PSU not having the -5v line option, as depicted on the PSU's label.
What I have observed from this experience is that there is no problem in booting. Just the said component refused to work. No other problems were noted.
Reply 6 of 18, by Cloudschatze
Why might that be? None of the Ensoniq cards I've seen have a -5v finger...
Some cards do exactly this. Instead of using the bus rail, -5v is "generated" onboard (e.g., the entire PAS line).
Reply 7 of 18, by retro games 100
Cloudschatze wrote:
Why might that be? None of the Ensoniq cards I've seen have a -5v finger... […]
I remember testing a PAS card, with a mobo that was powered by an ATX psu with no -5v. The sound coming from the PAS card was extremely strange, because the sound was greatly speeded up. (Of course, this strange behaviour may be a coincidence, and have nothing to do with the psu.)
The psu was a well known, modern model called Corsair HX520. Good quality, although very much geared up towards using it with a modern mobo, because it catered very well for the 12v rails.
Reply 8 of 18, by Cloudschatze
The PAS cards lack -5v fingers, so whether a PSU provides -5v, or not, is irrelevant.
The problem might have been timing-related. If you ever get the chance, try adding "t:1" to the mvsound.sys parameters. This configures the card to use its onboard timer, rather than the host timer, and might fix the playback-speed issue.
I'm not sure if anyone cares, but a few other well-known cards that use the -5v rail are the Sound Blaster 2.0, and Sound Blaster AWE32 Upgrade Card.
Reply 9 of 18, by retro games 100
Cloudschatze wrote:
The PAS cards lack -5v fingers, so whether a PSU provides -5v, or not, is irrelevant. […]
I definitely remember trying that "t:1" parameter you suggested many months ago, here on Vogons...but no joy I'm afraid. One day, I will dig out the PAS card again, and retest it in a different mobo.
Regarding the Sound Blaster 2.0 you mentioned directly above, is that the CT1600 model? If so, I bought one the other day, and I would be interested in testing it out on my current mobo+psu combo, the psu of which is the Corsair HX520, the one that lacks the -5v rail. (At least, I believe it lacks this -5v rail, as there is no mention of this specific piece of information on the Corsair website.)
Thank you, best regards, Robert.
Reply 10 of 18, by Cloudschatze
No, it's the CT-1350B.
The CT-1600 (SBPro2), ought to work just fine with your PSU.
Reply 11 of 18, by GL1zdA
It seems there will now be retro-PSUs 😀 The ATX spec dropped the -5V line in one of the latest revisions: ATX12V 2.1 (it wasn't required since ATX12V 1.2), so I probably buy some quality older PSUs before they vanish from the market.
getquake.gif | InfoWorld/PC Magazine Indices
Reply 12 of 18, by retro games 100
GL1zdA wrote:
It seems there will now be retro-PSUs 😀 The ATX spec dropped the -5V line in one of the latest revisions: ATX 2.1 (it wasn't required sinse ATX 1.2), so I probably buy some older quality PSUs before they vanish from the market.
Bloody hell! 🤣 That's another item to add to the retro shopping basket! 😉
Reply 13 of 18, by retro games 100
Please can you elaborate? What is a 7905 voltage converter? Is it something you can attach to a modern ATX 2.1 PSU?
Thanks a lot.
Reply 14 of 18, by Malik
Yep. That "vanish from the market" is a scary statement stuff, at least for us, nostalgia pursuers.
I better stock a couple too, at least, for the sake of my LAPC-I! 😁
Reply 16 of 18, by swaaye
No idea. The card just would not work until I put a PSU with -5v in. It refused to even initialize. Perhaps the motherboard needs -5v? It seemed fine though aside from the wacked out -5v reading in the BIOS and the ISA slots.
Reply 17 of 18, by swaaye
I'm sure they'll be available second-hand for decades to come. And ATX would probably have to be thoroughly obsoleted for new -5v ATX PSUs to go away completely anyway.
Reply 18 of 18, by retro games 100
I haven't tested the Roland LAPC-i internal soundcard, because I haven't got one, but the following hardware configuration seems to work -
ATX PSU (with no -5v rail) + ATX to AT power cable adaptor + 486 mobo + either SCC-1 or MPU-401AT
I tried running both Dark Forces (sound) setup utility, and also Roland's sound check utility (chkscc.exe), and both worked. I wonder if this test would work if I hooked up a Roland external module, such as a CM-32L? It should do, I reckon.
Is it just a small handful of old sound cards that require -5v rail on the PSU, or are there other old components which require it, such as graphics cards?
