First post, by unknowntbeast
Help! I mount the daggerfall.iso to R:\ then I go to R: and run the Install.exe, it starts the install wizard, and when it comes to the actuall install, it says there is not enough free space on my harddrive, HA! I've got about 90GB left free, I don't think it is even reconizing my harddrive b/c if I want to change the install directory, it says no drives found. So I figure thisis a DosBox problem....any ideas?
Running Vista Home Prem 32 Bit
-UnknownTBeast
Reply 1 of 2, by Qbix
Rank DOSBox Author
DOSBox Author
go to the elderscrolls forum. they have excellent guides on how to install the game in dosbox.
Water flows down the stream
Reply 2 of 2, by MiniMax
Rank Moderator
Moderator
Not a DOSBox problem, a PEBCAK problem.
_________________
