First post, by unknowntbeast
Help! I mount the daggerfall.iso to R:\ then I go to R: and run the Install.exe, it starts the install wizard, and when it comes to the actuall install, it says there is not enough free space on my harddrive, HA! I've got about 90GB left free, I don't think it is even reconizing my harddrive b/c if I want to change the install directory, it says no drives found. So I figure thisis a DosBox problem....any ideas?
Running Vista Home Prem 32 Bit
-UnknownTBeast
