First post, by felipe.sanches
Pinball Fantasies uses 2 palettes simultaneously (top half and bottom half of the screen) in its intro screen but dosbox does not render it properly.
I have tryied machne=vgaonly but it did not fix the issue.
Reply 3 of 11, by ripsaw8080
Rank DOSBox Author
DOSBox Author
An interesting side-effect is that you see the wrong palette for the lower picture on the screen, but a screenshot taken by DOSBox (Ctrl-F5) has the correct palette for the lower picture.
    21.5 KiB
    Screenshot taken by DOSBox
    21.48 KiB
    Screenshot taken by Windows
Reply 5 of 11, by ripsaw8080
Rank DOSBox Author
DOSBox Author
I used my own build of (fairly) recent CVS with svga_s3. I just now tried it with vgaonly and the palettes are working correctly. I thought the OP said that it had been tried... guess not.
Reply 7 of 11, by Qbix
Rank DOSBox Author
DOSBox Author
maybe he typed
machine=vgaonly inside dosbox.
machine is one of the settings that isn't changable during runtime
Water flows down the stream
Reply 8 of 11, by felipe.sanches
maybe he typed
yes.
Now I tried setting -machine vgaonly in the dosbox command-line and it worked. Thanks.
So, the bug report is: please report to the user when a certain settings parameter is not configurable during runtime.
Reply 10 of 11, by felipe.sanches
I have written a patch that fixes this behaviour.
But I am not used to CVS. Is there a way do create a patch just like "svn diff > my patch.diff" does ?
Reply 11 of 11, by felipe.sanches
cvs diff -u 😁
Here is the patch!
