First post, by JamesS
Hello, I am have an issue running QG4 with gus correctly.
I used the custom dosbox install to install from my CD.
I then copy the sierra Gus patch for QG4 into the directory.
I run dosbox and manually edit the resource.cfg pointing to the gus drvs.
I then run the loadpats to load the GUS instruments.
I get amazing Gus music for the sierra fanfare, and intro.
Then, when loading into the cave it always crashes, with this error in the console, illegal descriptor type 0 for int D.
If I change the driver for sound to the standard DACBLAST for soundblaster I can run the game with the great GUS music, but most of the sound fx don't play or when they do they sound like crappy adlib.
If I run with adlib music and soundblaster sound I get decent sound fx but crappy music. Has anyone else run into this, and is there a way to get this to work.
