First post, by McPat
I have a registered copy of Dragons Bane (Nels Andersons updated Mahjongg). The game must be installed from the disk because it creates a registration file. With the registered version it is possible to load user created tiles. I installed it from the disk and created my user ID as requested. However, when I play the game in DosBox, it says it is not registered. Yet, when I check the directory the game is in, the registration file is there.
My OS is Vista Ultimate (ARGH), and I have an ASUS P5AD2 Pentium 4 motherboard with built in RAID controller. Also have an ASUS Extreme A X600 video card.
It seems to me that the game is not finding the right path for the registration file. Any ideas why it won't show that the game is the registered version?
McPat
Reply 1 of 19, by eL_PuSHeR
You are talking about writing some file(s) to disk, you must mean floppy? Did you mount it as floppy?
[MOVED]
Intel i7 5960X
Gigabye GA-X99-Gaming 5
8 GB DDR4 (2100)
Reply 2 of 19, by Dominus
Rank DOSBox Moderator
DOSBox Moderator
It might be that the game tries to "register" something of the c-drive or tries to write something to it that is not supported by Dosbox. I have a similar issue with the full floppy disk version of Inner Space. The game writes something on the floppy disk when you install it. Whatever it does, it is not working with normal Dosbox.
BUT you can try with an image disk with Dosbox. A guide to this is at Sample usage of a harddisc image in DOSBOX. There on step 6, instead of "boot -l c", just mount your floppy disk as well and try to install the game. If it still complains, make an image of your floppy disk, go to step 6 of that guide and imgmount that floppy image as well and then "boot -l c".
Windows 3.1x guide for DOSBox
60 seconds guide to DOSBox
Reply 5 of 19, by MiniMax
Rank Moderator
Moderator
Or it could be that this registration file is supposed to be hidden, and when the application test for the hidden attribute it gets the wrong answer from DOSBox. AFAIK DOSBox does not honour these attributes.
Edit: Re: Can't Get Global Conquest to run, the horror!
_________________
Reply 6 of 19, by McPat
This is EXACTLY what the program does. The reg file is a hidden file. Co you think if I zipped the file, put it in C:\Oldgames and then installed it from there that it would work? Or if I created an image file?
Reply 7 of 19, by DosFreak
If you have a DOS file with the hidden attribute then DOSBox will still see it. The only way around this currently is to install MS-DOS in DOSBox.
Make your games work offline
Reply 8 of 19, by MiniMax
Rank Moderator
Moderator
Discussion about a TSR for fixing attributes:
_________________
Reply 9 of 19, by rfnagel
MiniMax wrote:
Discussion about a TSR for fixing attributes: Can't Get Global Conquest to run, the horror!
Unfortunately that TSR doesn't work for Dragon's Bane (or "Second Guess" for that matter). The TSR looks for the file "$$$steal.me", but after hex editing the TSR to point to Dragon's Bane registration file ("DRAGON.REG"), the game still was unregistered.
I'm not a programmer (so it all looks like 'greek' to me <G>), but (even after hex editing the TSR to point ot the correct file) I think the problem is that the TSR *also* sets the 'system' and 'read-only' file attributes. After testing Dragon's Bane and Second Guess on another (older) PC of mine that didn't require DOSBox to get them to run, I noticed that they also were still unregistered when settin the 'sys' and 'r/o' file attributes for their registration files.
BTW, for Second Guess the file is "GUESS.REG".
Rich ¥Weeds¥ Nagel
http://www.richnagel.net
Reply 10 of 19, by ripsaw8080
Rank DOSBox Author
DOSBox Author
That TSR was rather specific to Global Conquest; another one for Elite is more suitable under the circumstances: "Elite" (1987) save/load problem request.
It applied attributes to files with a particular extension (.CDR), but can easily change it to .REG (it is case-sensitive, so might need different case depending on the program). It reported NO attributes (CX=0), but easy to change to hidden (CX=2).
The attached TSR looks for .reg extension, case doesn't matter, and hidden attribute only. Change the attribute bits as necessary if something else is needed.
EDIT: removed non-working version of TSR
Reply 11 of 19, by rfnagel
Many thanks for the utility ripsaw8080! 😀 Unfortunately it doesn't seem to work. Dragon's Bane (as well as Second Guess) still say that they are unregistered when starting them.
Is there any way to confirm that the REG files are actually being set as 'hidden' under DOSBox? I have W98SE's ATTRIB.EXE in my DOSBox games directory (using DOSbox's "VER SET 7 10" command I can run W98SE's "Attrib" executable to check file attributes), but it still reports that the file is not hidden when viewed under DOSBox and with the TSR loaded.
Rich ¥Weeds¥ Nagel
Reply 12 of 19, by ripsaw8080
Rank DOSBox Author
DOSBox Author
When I use ATTRIB.EXE from MSDOS 5 or 6 to check the flags in DOSBox, any file with an extension of .REG shows as hidden when the TSR is loaded. Not sure why the one you're using would be any different.
As for it not working for the game, it was a shot in the dark. The game may look for more than just the hidden attribute, so it's a good idea to see what attributes are assigned to the file when installed in the NTVDM. Wouldn't be surprising if it was marked as read-only and archive, for instance. Also, the game may expect some other consequence of the file being hidden that I could only guess at.
Reply 13 of 19, by MiniMax
Rank Moderator
Moderator
rfnagel - you know that you have to run/load that REGFIX *immediately before* you run the game? In the same DOSBox session.
_________________
Reply 14 of 19, by rfnagel
That's really weird. I'll have to try one of the older versions of ATTRIB that I have on another PC.
(edit) Just tried MS-DOS's v6.22 ATTRIB.EXE, and it indeed shows the file having the Hidden attribute set when the TSR is running. A strange thing, Norton Commander (v5.0) doesn't show the file as being hidden (NC normally has a little ASCII checkerboard character next to any files that are tagged has hidden).
I tried it under my W98SE PC shelled out of Windows. The file on the floppy is only has the hidden attribute set, and the same for when the game is actually running (I ALT+TABbed back to Windows and had a looksie at at). Actually, the file also has the archive attribute set, but during my experimenting on the W98SE PC, the only thing the game seemed to care about was having the hidden attribute set, and the system attribute not set (it seemed to ignore it if the read-only attribute was set).
Yep yep 😀
Rich ¥Weeds¥ Nagel
Reply 15 of 19, by ripsaw8080
Rank DOSBox Author
DOSBox Author
I downloaded the game in shareware form (v1.2), and it's using FindFirst rather than getting the attributes directly. A bit twistier, but can still work around it. The game will open and read the reg file with the modified TSR that I've attached, but without valid contents, I can't say for sure if it will work 100%... but it's progress. 😀
    REGFIX.ZIP
    865 Bytes
    210 downloads
Reply 16 of 19, by rfnagel
U da man, Ripsaw8080! Many thanks, it works like a champ! 😀
    121.7 KiB
Rich ¥Weeds¥ Nagel
Reply 17 of 19, by rfnagel
Piccy #2 😀
    104.39 KiB
Rich ¥Weeds¥ Nagel
Reply 18 of 19, by eL_PuSHeR
Offtopic:
Nice GIF images, but PNG compression is better than GIF one.
95,4 KB for image one (dragon), 69,7 KB for image two (kids).
Intel i7 5960X
8 GB DDR4 (2100)
Reply 19 of 19, by rfnagel
BTW, duno if anyone is playing these gems, but I finally decided to get off my arse and upload some of my old creations for the two games ("Dragons Bane: Mah Jongg II" and "Second Guess")... layouts, tileset, background images, and such.
Surf here http://jasonwilliams400com.startlogic.com/sno … e_Mah_Jongg_II/ to snag what ever ya want 😀
Hehe, I remember some of the older DB stuff I had originally uploaded to Nels Anderson's original "Arcanum BBS" (long distance dialup), that was well before Al Gore 'invented the Internet' <G>.
Rich ¥Weeds¥ Nagel
