Zip only contains Glide2x.dll?
General information and assistance with OpenGLide.
Postby plank » 2006-2-03 @ 22:27
Is something missing?. How can Glide2x.dll act as a Glide wrapper?. Does the .INI file generate after running the Glide-based program or something?
plank
Re: Zip only contains Glide2x.dll?
Postby Glidos » 2006-2-03 @ 23:20
Glide2x.dll is all you need for Windows based Glide games.
User avatar
Glidos
Postby Guest » 2006-2-04 @ 03:06
I see, thankyou. How come people mention an INI file though?
Guest
Postby DosFreak » 2006-2-04 @ 03:27
IIRC, the .ini is generated upon first use of a game with the glide wrapper. You can then modify the .ini later if the default settings do not work well with the game.
User avatar
DosFreak
Postby Zirias » 2010-5-28 @ 08:48
Note that the .ini just appears in the "current" directory, which is on a windows based system normally the same directory that contains the .exe file of the game (or dosemu).
I think this is quite broken behavior, it clutters your system with .ini files and requires write permission in every game directory. I started a partial fix in the "development" forum for linux/unix machines that places the .ini file inside ~/.openglide -- for windows this should probably be %APP_SETTINGS% ...
To support games that need different openglide settings, i think an environment variable like $OGL_CONFIG should be used to provide a non-standard .ini-name. But that's better discussed in the development forum ;)
For now, just be sure you have write permission in the "current" directory when using openglide.
Zirias
Postby Glidos » 2010-5-28 @ 09:31
I used the registry and a config program with psVoodoo
User avatar
Glidos
Postby Glidos » 2010-5-28 @ 09:32
... which was a silly thing to say for a program that builds also for Linux and Mac. :happyhappy: Paul is only half awake this morning
User avatar
Glidos
Return to OpenGLide General
Who is online
Users browsing this forum: No registered users and 0 guests
