DOSBox SVN Builds
Developer's Forum, for discussion of bugs, code, and other developmental aspects of DOSBox.
DOSBox SVN Builds
Postby HunterZ » 2005-7-04 @ 17:41
The contents of this post have been moved to the DOSBoxWiki:
http://www.dosbox.com/wiki/SVN_Builds
Please feel free to discuss SVN build-related news/info in this thread.
Please do not post bug reports here. If you've found an SVN bug, please make sure it occurs in a vanilla SVN build; if it does, compare behavior to the official 0.74 release and create a new thread in this sub-forum to discuss the results. Be sure to mention which SVN revision you encountered the issue with.
Also note that posts may be deleted or split off into new threads from time to time at moderator discretion if things wander too far off-topic!
User avatar
HunterZ
Re: DOSBox CVS Builds
Postby NoVaTuRiEnT » 2010-4-13 @ 00:00
HunterZ wrote:
lightmaster wrote:there's an error in tharo's cvs builds right? cant see april ones D:
Yeah, looks like nothing has been built since 28 Mar.
Was good while it lasted. Oh well.
There's always emucr - http://www.emucr.com/
i7 965 @ 3.20GHz | GTX480 | 12GB DDR3 RAM @ 7-7-7-20 1T 1333MHz
2x Velociraptor (600+300GB) HD | 1x WD MyBook 1TB External USB3 | BenQ XL2410T 120Hz
Logitech G9x/G15 | ASUS Xonar D2X PCI-E | Win7 x64 Home Premium
NoVaTuRiEnT
Postby XTale » 2010-5-02 @ 00:10
The "tharos" build did stop because my server died ;)
I've a new one, but the cross-compile-environment is not working as it should....
As I'm really busy atm I don't know when I've the time to fix this stupid system.. but I'll post once it is done
http://www.aep-emu.de - AEP Emulation Page
http://cvscompile.aep-emu.de - DosBox CVS builds
User avatar
XTale
Postby kekko » 2010-5-06 @ 21:18
Dosbox full changelog from the beginning of time
http://dosbox.svn.sourceforge.net/viewv ... /?view=log
User avatar
kekko
SVN build for debian
Postby Zirias » 2010-5-09 @ 15:08
Just to mention: I just uploaded an SVN build for Debian GNU/Linux i386 and amd64 including glide stuff, look here:
viewtopic.php?p=186679#186679
No idea right now if i'll continue on this, though.
Zirias
Postby Qbix » 2010-5-24 @ 08:35
Water flows down the stream
User avatar
Qbix
DOSBox Author
Postby gulikoza » 2010-7-30 @ 16:30
gulikoza is still here...a bit busy though :) See Virusek build, it has the same patches as my previous build. I am meanwhile trying to refresh my patches...
User avatar
gulikoza
Postby ykhwong » 2010-8-02 @ 10:56
And Daums Cafe is down afaik, but i guess it's because he ykhwong is still doing his military service.
Heh, I'll discharge from the military service soon (August 11th 2010). :)
Today, I bought a web hosting service and moved my website to http://www.thx4good.x-y.net (http://ykhwong.xo.st/)
ykhwong
Re: DOSBox SVN Builds
Postby jbailey8 » 2010-10-29 @ 19:16
I can compile svn versions, I've done this with both visualc and intel
compilers, if you want, I can compile on a set schedule, and post the
latest exe somewhere that other people could get it. Let me know if
your interested.
User avatar
jbailey8
Postby wd » 2010-10-29 @ 19:40
Did you talk to Qbix or somebody about this? I pretty much dislike advertising
*DEVELOPMENT* builds even more than the dev forum (which should not contain
links to prebuilt versions either IMO).
wd
DOSBox Author
Postby HunterZ » 2010-10-30 @ 22:04
*DEVELOPMENT* builds even more than the dev forum (which should not contain links to prebuilt versions either IMO).
No, but I don't think he has a problem with it since he edited it to correct some links (I'm assuming he's WikiSysop). It's worth noting that it's not linked from anywhere else in the wiki either (let alone the main page), so you pretty much have to know it's there to even find it.
It's already been a lot nicer having it in the Wiki where the build maintainers can update the info on their own builds as they see fit, but I of course would move it back here if Qbix or Harekiet were to request that I do so.
User avatar
HunterZ
Postby ykhwong » 2010-11-19 @ 15:45
Looks like h-a-l-9000 updated the SVN Builds page on the Wiki to announce that MB6 has been released.
Thanks for the info. ;)
In hal's MB6 build, cycles=max with DOS_IDLE (on shell prompt) does not stop increasing CPU cycles. Too high cycles make DOSBox just stop working in the end. It does not matter only with dynamic core, though.
ykhwong
Postby h-a-l-9000 » 2010-11-19 @ 17:23
So it's fixed cycles for a year or so :)
1+1=10
h-a-l-9000
DOSBox Author
Postby ykhwong » 2011-1-19 @ 04:33
It is mostly like Wikipedia but seems somewhat limited, probably due to low version of wiki software? There is no way to upload image files. It says "File uploads are disabled." Many pictures are old or outdated. Some months ago, I updated some other pages so that people will not download older versions of DOSBox, anyway.
It needs to revise main page and its links to other pages. (Vista Specific Issues->Vista/7 Speicific Issues: as there is Win7 also, Keymapper->Mapper: because it also can remap joystick, and so on) No privilege to edit, sadly.
What about adding a link to how to use signature in discussion page like this?
http://en.wikipedia.org/wiki/Wikipedia:Signature
So dizzy... When I see some talk pages, I don't understand who wrote a question/comment at a glance. Look at Talk:Main Page.
http://www.dosbox.com/wiki/Talk:Main_Page
ykhwong
Postby Dominus » 2011-9-04 @ 22:38
I'm scripting an automatic dosbox snapshot creation on SVN changes for OS X. Right now the universal binary can be downloaded from http://dl.dropbox.com/u/7737184/Dosbox/ ... apshot.dmg (the url might change in the future).
Universal binary means it is for PPC and Intel Macs (only 32bit since 64bit Dosbox is much slower).
No additional patches applied, a clean SVN built.
Is there a mailing list of SVN changes? I'd like to subscribe to make my automation fully work :)
User avatar
Dominus
DOSBox Moderator
Postby Qbix » 2011-9-05 @ 06:24
http://sourceforge.net/mailarchive/foru ... ox-cvs-log
Not sure if it works. Ask harekiet where he gets his int0x21 data from
User avatar
Qbix
DOSBox Author
Postby Qbix » 2011-9-05 @ 06:44
https://lists.sourceforge.net/lists/lis ... ox-cvs-log
although I recommend you asking harekiet. not sure if that mailing list is still used
User avatar
Qbix
DOSBox Author
Postby HunterZ » 2011-12-15 @ 16:55
Trimmed this thread a bit, and updated the wiki page (thanks Qbix for re-enabling access). Lots of builds moved to the "no longer updated" list due to being at least a year old. Now we're down to one pure and one custom SVN build in the active lists :(
User avatar
HunterZ
Postby DosFreak » 2011-12-15 @ 17:41
How is Megabuild Obsolete? Especially since DOSBox 0.74 is the latest official release.....
User avatar
DosFreak
Postby HunterZ » 2011-12-15 @ 18:01
DosFreak wrote:How is Megabuild Obsolete? Especially since DOSBox 0.74 is the latest official release.....
MB6 is based on SVN r3661, not 0.74. If h-a-l-9000 re-baselines it to be based on 0.74 then that's a different story.
User avatar
HunterZ
Next
Return to DOSBox Development
Who is online
Users browsing this forum: Google Feedfetcher, Majestic-12 [Bot] and 2 guests
