First post, by HunterZ
- l33t++
The contents of this post have been moved to the DOSBoxWiki:
http://www.dosbox.com/wiki/SVN_Builds
Please feel free to discuss SVN build-related news/info in this thread.
Please do not post bug reports here. If you've found an SVN bug, please make sure it occurs in a vanilla SVN build; if it does, compare behavior to the official 0.74 release and create a new thread in this sub-forum to discuss the results. Be sure to mention which SVN revision you encountered the issue with.
Also note that posts may be deleted or split off into new threads from time to time at moderator discretion if things wander too far off-topic!
