Fallout 1
Reply 40 of 45, by HunterZ
Unzip the ZIP file in Windows and dump its contents in the Fallout folder, then open DOSBox and navigate to the Fallout directory and run the patch installer from there.
Reply 41 of 45, by Phulax
And the patch produces a Windows executable file so how's that going to work in DB?
Reply 42 of 45, by Phulax
I tried that but DB didnt recognize the file but I'll try again.......
Reply 43 of 45, by Phulax
what's the command to unzip fallup1w in DB?
Reply 44 of 45, by SKARDAVNELNATE
Download the patch for the DOS version. Click here.
It will contain a PATCH.TXT document. Read it.
You do that part with Windows. Then place the files it produced in your fallout directory.
Reply 45 of 45, by Phulax
TY!!! I unzipped the download into a separate file then copied & pasted it into the FO DOS & ran it & it's now v1.1
TY very much!
