CVS Builds (once a week)
Reply 20 of 123, by murlock
jez wrote:
From CVS? So, you can run ./autogen.sh and ./configure from MSVC6, can you?
Yes from CVS and no, you don't need to use autogen.sh & configure.
You open the .DSP (or .DSW) with VC6 and specify where are the includes and librairies of SDL, PNG and NCurses
if you want changes somes settings, look for config.h in src/platform/visualc
Reply 21 of 123, by rjpa
murlock, can you please provide me with a small guide, how you compile DOSBox with SDL,SDL_net,LIBPNG,ZLIB and Debug mode via Visual C++ 6.0 ?? So I can provide users with CVS versions with both debug and without..
/rjpa
Reply 22 of 123, by Qbix
Rank DOSBox Author
DOSBox Author
don't use Visual C++ 6.
it creates wrong code......
Sorry.
We switched to vs.net
You'll need to compile SDL with an option so it doesn't grab the std in and std output.
and then configure pdcurses or another curses...
Will see if I can get it running myself...
Water flows down the stream
Reply 23 of 123, by Snover
Qbix: I still can't get it to compile properly with VS.net...
Yes, it’s my fault.
Reply 24 of 123, by Qbix
Rank DOSBox Author
DOSBox Author
edited first post to display debug released version as well
Snover: hmm still problems. I saw harekiet committed quite some fixes yesterday or so....
Reply 25 of 123, by jez
Or use a real compiler, like MingW or Cygwin gcc 😉
BTW that option you're talking about is probably ./configure --disable-stdio-redirect and it's mentioned in my other thread about DOSbox as a console application.
== Jez ==
Reply 26 of 123, by Carrera
Total N00b question: What is CVS?
What is it good for?
Where I come from it is a pharmacy chain...
Reply 27 of 123, by rjpa
It is the latest developer release, not stable and not supported. But it runs some protected mode games.
/rjpa
Reply 28 of 123, by murlock
I've try to compil the CVS version with the third post on this potics and it's doesn't works with MinGw:
No ./configure and if I run autogen.sh no autogen, autoconfig, autolocal ...
If I get the archive from http://pcnwstage.phys.rug.nl/dosboxcvs.tgz , all is perfect except maybe : which version of CVS I use ?
Another Remarks:
If I read the Post, when I've made the ./configure for SDL, I've got a DirectX librairies: No, Is SDL in this case use only GDI ?
Maybe there is somes steps to add for use the CVS version with MinGW...
Reply 29 of 123, by Qbix
Rank DOSBox Author
DOSBox Author
the regular cvs never has a configure (and probably never will).
The archive at http://pcnwstage.phys.rug.nl has it. That's because I add it to it. You'd better use that version. It's updated twice a day with the current cvs code so you lag at most 12 hours.
Qbix
Reply 30 of 123, by murlock
Qbix wrote:
the regular cvs never has a configure (and probably never will)Qbix
Ok... nice to know that (time to get VC.NET 😉 ) because sometimes I love to digs in source code !
Reply 31 of 123, by Snover
Stupid, stupid SF.net is still running WebCVS against their backup CVS server, and now TortoiseCVS can't update my sources...
Yes, it’s my fault.
Reply 32 of 123, by nuclear0508
you compress the exe file with aspack.
can you pack it by upx or do not compress it?.
Reply 33 of 123, by Qbix
Rank DOSBox Author
DOSBox Author
Any particular reason for that ?
the resulting exe's are accaptable for it's size.
Reply 34 of 123, by rjpa
Why shouldn't I pack it? I doesn't matter, the build system automatically compresses it using ASPack. It doesn't decrease any performance at all.
/rjpa
Reply 35 of 123, by BatCountry
Getting the CVS to compile under MingW:
Very first thing. Pick up msys, the minimal system for MingW. This gives you a basic sh to run scripts in.
First of all, you're going to have to run "./autogen.sh". For that you'll either need a LOT of junk for msys, like automake and autoconf (which each have mad dependencies), or you could just pick up a small install of cygwin and run "./autogen.sh" under that. (which I did).
Second, if everything succeeded in autogen, start up msys, switch to your dosbox CVS directory, then run "./configure". Remember you're going to need SDL (so compile that and move its includes and libs into somewhere the compiler can find them), libpng (for screenshots, optional; and its dependencies: libz - rename to zlib), and (if you want debugger) curses
Done with all that? Good. If configure worked out all right, you should have a makefile. Know what to do with that? If so, great, if not, type "make", then when that gizmo is done, type "make install".
When that's all done, good lord willin' and the crick don't rise, you've got "dosbox.exe" in your msys path under "/usr/local/bin". If not, well, er, you've got problems.
Reply 36 of 123, by necrolust
Was anyone able to get the OCT02 build? I'm seeing a 1k zip file.
paul@rvt.com
Reply 37 of 123, by rjpa
Over at files.pixelz.org it is complete, download the build, it should be quite much larger than 1k.
/rjpa
10 PRINT "rjpa rocks!";
20 GOTO 10
Reply 39 of 123, by rjpa
Yes, go to http://forums.pixelz.org and sign up. And then read the instructions on how to download the builds.
Cheers
rjpa
20 GOTO 10
