Ruined these (retro) hardware today
Reply 20 of 24, by iulianv
Late in the evening I finally remembered that I had some Jetway SS7 board that wouldn't POST, so I dug it up and found a 32-bit EEPROM on it.
Put it in one of those RTL8139D cards and tried UniFlash -PCIROM, with no luck (while experimenting I also managed to get a Biostar socket7 board stuck at "Verifying DMI pool data...", just to keep this thread alive 😜 ).
At this point I had no choice - I had to use my preciouss ASUS P2B-D/1.06/D03 for my first hotflash ever. Fortunately everything went great, so I now have my 486 board back, alive and kicking with a newer BIOS version 😁 .
Reply 21 of 24, by Malik
Good to know that! Hotflash and Uniflash. Made for each other. 😁
Reply 22 of 24, by h-a-l-9000
Rank DOSBox Author
DOSBox Author
> RTL8139D
The D version has the flashing interface castrated off.
1+1=10
Reply 23 of 24, by Tetrium
Old Thrashbarg wrote:
Unfortunately I don't have another PCI socket3 board with AWARD BIOS
It doesn't have to be a PCI Socket 3 board to do a hotflash... it can be any kind of board that uses a similar type of flash chip. Sometimes it can be done with the boot ROM socket on a network card too, if you can find a NIC with the write-protect disabled.
Is it possible to use old NIC's to flash a motherboard BIOS chip??
If so, that would be AWESOME!
I really dislike the idea of having to swap chips when the computer is running.
My retro rigs (old topic)
Report spammers here!
Reply 24 of 24, by retro games 100
But it's exciting! 😉 😀
