First post, by jim78b
why DOS Bosbox sometimes in some games don t emulate video filters like crt emulation or scanlines .i try the games machine ANC i want use crt filter but it has no effect on it!
Reply 1 of 7, by ripsaw8080
Rank DOSBox Author
DOSBox Author
You can try adding "forced" on the scaler setting (e.g. "scaler=tv2x forced"), but it may not help in all cases. Some graphics and text modes are double-height or double-width, and DOSBox has internal scalers that are used in such cases. If, for example, the program you're running uses a double-width mode like 320x400x256, the internal double-width scaler will override your choice of scaler. If possible, use a different video mode that allows your chosen scaler.
Reply 2 of 7, by jim78b
OK BUT YOU CAN TRY WITH THE INCREDIBLE MACHINE, I WANT EMULATE CRT MONITOR WITH SCANLINES BUT IT DON'T work!
Reply 4 of 7, by jim78b
i use frontend dfend and select crt monitor or upscaling
Reply 6 of 7, by jim78b
you tell me thath i use notepad and modify dosbox.conf?
Reply 7 of 7, by jim78b
i use in dfend simulates phospors on dot trio crt....it is right?
