First post, by jim78b
- Member
why DOS Bosbox sometimes in some games don t emulate video filters like crt emulation or scanlines .i try the games machine ANC i want use crt filter but it has no effect on it!
You can try adding "forced" on the scaler setting (e.g. "scaler=tv2x forced"), but it may not help in all cases. Some graphics and text modes are double-height or double-width, and DOSBox has internal scalers that are used in such cases. If, for example, the program you're running uses a double-width mode like 320x400x256, the internal double-width scaler will override your choice of scaler. If possible, use a different video mode that allows your chosen scaler.
OK BUT YOU CAN TRY WITH THE INCREDIBLE MACHINE, I WANT EMULATE CRT MONITOR WITH SCANLINES BUT IT DON'T work!
Perhaps it doesn't work because your keyboard is broken?
Did you actually try what ripsaw posted?
i use frontend dfend and select crt monitor or upscaling
Then takeit up with dfend to use the forced setting
you tell me thath i use notepad and modify dosbox.conf?
i use in dfend simulates phospors on dot trio crt....it is right?
