First post, by kemot001
- Newbie
I think i have seen it before somewhere but cant remember where and what was the name of this sound card. Anyone got idea ???
My retro sound card collection
http://retrosoundcards.wordpress.com/
I see a CS4248 and a YMF262, it's definitely a Windows Sound System card. The OEM isn't seen on this one though, I remember a Diamond CD-ROM kit having a card just like this
What's written on the rectangular chip with the many pins on all sides?
1+1=10
Thank You that could be it , but windows soundsystem card should have
windows SOUNDSYSTEM written on it 😕
Mayby its a clone of windows soundsystem ???
This seems to be more than a WSS
1+1=10
Found this from its FCCID: http://laurent.caprani.free.fr/sc-6000/index.html
wss should look like this
For Hal
its a gallant !
Once again thank all for your help
kemot001:
I have changed your first card capture. It was too wide. I also adjusted contrast and blurriness a bit.
BTW: Imageshack SUCKS. 😠
This looks like a pretty nice card. I like the RCA jacks. Is the unmarked chip likely an one of those opti 929 things? According to the FCCID, it is "SC 6000", though it doesn't look like any of the ones I have seen.
I've never seen this one either. It has an own MCU too.
The 82C929 'translates' the SB interface to WSS. This card is similar.
1+1=10
its definetly Gallant SC-6000 Sound Card like ripsaw8080 posted
This beauty should soon be im my hands will see what "she" can do
It is almost identical to my Terratec Maestro 32 (2nd edition): ASC-9308 + DSP-9309A + CS4248 + OPL3. This terratec card uses the same PCB as the Gallant SC-6000. Sometimes the CS4248 codec chip is the replaced with a pin compatible AD1845.
Your card seems to have a different PCB, without volume wheel and gameport. But the chips are exactly the same. It has no Wavetable by itself. The ASC-9308 controller chip is by C-Media, it gives SB-Pro and MPU-401 compatibility. Though the SB-Pro compatibility was not flawless last time I checked. There was a SB-Pro DSP version changer and a SB16 utility for this card. The SB16 utility did not work for me at all.
Is that "DSP" really a DSP? It looks more like a controller for the CD-ROM interfaces.
wrote:Is that "DSP" really a DSP? It looks more like a controller for the CD-ROM interfaces.
It says DSP-9309A on the chip. My first guess was that the chip may be doing MPU-401 interfacing.
Digging out this old thread to clarify that the Gallant SC6000 card is similar to the Terratec Maestro 16 sound card and not to the Maestro 32 (OPTi 929 based). Compatibility of the Maestro 16 is better than Maestro 32.
www.AmoRetro.de Visit my huge hardware gallery with many historic items from 16MHz 286 to 1000MHz Slot A. Includes more than 80 soundcards and a growing Wavetable Recording section with more than 300 recordings.
