DosBox Air Power
First post, by Morgantao
Hi guys,
I'm trying to play the ever so nostalgic Air Power simulator (Mindscape, 1995), but I just can't get it to run...
The best I could master was seeing the Mindscape logo, and then crash back to dos with error 55 (which is an internal error code, so it doesn't really help).
Anyone has any solution? Is there anyone here who could make the game work?
Thanks!
Reply 1 of 5, by Dominus
Rank DOSBox Moderator
DOSBox Moderator
Please follow the 60 seconds guide from the guides forum (especially the game installation in dosbox), and then report back.
Windows 3.1x guide for DOSBox
60 seconds guide to DOSBox
Reply 2 of 5, by Morgantao
I have 2 versions of the game:
1) "original" version in 6 ZIP files, each one is a floppy
2) pre-installed game, with all the files already extracted from the floppies.
When I try to install the game from the floppies, the installer keeps telling me to insert floppy #1 (which is absurg, because INSTALL.EXE is on floppy #1), and none of the 6 floppies makes the installer happy...
When I try to run the pre-installed version, I get the following mesage:
ERROR: LIB LOAD 55 0Last file access:libs640.400\SGA_BITZ.bin
Note that I have ran SVGAVESA.EXE to install the vesa driver, and it's test was ok.
Reply 4 of 5, by Morgantao
🤣, I don't have a floppy drive for years now...
And what do you mean abandonware? I thought this WAS abandonware. 😕
Reply 5 of 5, by wd
Rank DOSBox Author
DOSBox Author
This is copyrighted software.
