First post, by eL_PuSHeR
Why there is no P330 midi port value with default value? Yes, i know you can modify it in the configuration file but i was wondering why.
Reply 1 of 2, by Nicht Sehr Gut
Originally posted by eL_PuSHeR Why there is no P330 midi port value with default value? Yes, i know you can modify it in the configuration file but i was wondering why.
IIRC, you can always add it (P=330), but I think that port 330 became so universal that people just ignored setting it in the "SET BLASTER" line and just presumed that it was always 330.
Reply 2 of 2, by eL_PuSHeR
OK, thanks for your reply.
