First post, by jim78b
- Member
vorrei usare lo schema dei colori CGA in window xp, qualcuno sa i codici e come metterli per usarli nel desktop di window?
BEST REGARDS
BEST REGARDS
We use English here. Thanks.
I would use the color scheme of CGA in window xp, does anyone know the codes and how to put them to use them in the desktop window?
Here are the RGB values for the 16 CGA colors :
Color Hex Value R G BBlack 00h 0 0 0Blue 01h 0 0 170Green 02h 0 170 0Cyan 03h 0 170 170Red 04h 170 0 0Magenta 05h 170 0 170Brown 06h 170 85 0White (Light Gray) 07h 170 170 170Gray (Light Black) 08h 85 85 85Light Blue 09h 85 85 255Light Green 0Ah 85 255 85Light Cyan 0Bh 85 255 255Light Red 0Ch 255 85 85Light Magenta 0Dh 255 85 255Yellow (Light Brown) 0Eh 255 255 85High Intensity White 0Fh 255 255 255
I think he wants the Light Magenta/Light Cyan/High Intensity White/Black colors
Debian's fucked
YES THE 4 COLORS OF CGA! BUT HOW I CHANGE AND SET THEM IN WINDOW? HAVE YOU SUGGESTION?
BEST REGARDS
wrote:YES THE 4 COLORS OF CGA! BUT HOW I CHANGE AND SET THEM IN WINDOW? HAVE YOU SUGGESTION?
BEST REGARDS
1) Right click on desktop, click properties.
2) Select Appearance tab
3) Click Advanced
4) Click on the element you want to edit and click on "Color"
5) Click "Other"
6) Insert color value from the above table
Enjoy 😀
ok thanks but which color i assign exactly to desktop, windows etc..?
Whichever one you think looks best.
vorrei mettere in proprieta -> impostazioni di window non 65.000 colori ma 4 colori in modo che window li misceli automaticamente con tutto, perfino per le icone, è possibile?
ENGLISH
wrote:vorrei mettere in proprieta -> impostazioni di window non 65.000 colori ma 4 colori in modo che window li misceli automaticamente con tutto, perfino per le icone, è possibile?
Are you talking about running the Windows XP desktop in 4-color mode? The lowest I've ever seen anyone get it down to is 16 colors (i.e. standard VGA). Other than that, you'll pretty much have to resort to screwing around with the appearance settings.
GUIs and reviews of other random stuff
Вфхуи ZoPиЕ m
СФИРEt. SEPOHЖ
Chebzon фt Ymeztoix © 1959 zem
then you can not do as I say?
wrote:then you can not do as I say?
We don't know what you said, because we can't read your language!
ToastyTech has a few shots of Windows 95 running in very low-color modes, but I doubt the same tricks can be applied to Windows XP.
http://toastytech.com/guis/misc2.html
excuse me for my english but i'm italian!
thank the site it is very interesting!
i suppose i will create my personal 4 colour icons!
(I speak Alienware!) 🤣
"The height of strategy, is to attack your opponent’s strategy” -Sun Tzu
“Make your fighting stance, your everyday stance and make your everyday stance, your fighting stance.” - Musashi
SET BLASTER = A220 I5 D1 T3 P330 E620 OMG WTF BBQ
Just for your reference, here's each RGB palette in normal and high intensities.
http://uncyclopedia.wikia.com/wiki/Monitor#Co … apter_.28CGA.29
Enjoy the humor too. 😀
Вфхуи ZoPиЕ m
СФИРEt. SEPOHЖ
ok but it would be nice if xp to mix the colors I want, there is no software on purpose?
